Alloy welding question.
Has thanked: 9900 times
Been thanked: 10212 times
To weld an alloy frame part on a bike,does the battery need to be disconnected?
Has thanked: 541 times
Been thanked: 7591 times
Re: Alloy welding question.
To weld ANY part on a car or motorcycle you need to disconnect the battery, IMHO.
I had a professional weld an alloy mount point on a Ducati engine. He insisted I removed any parts that were sensitive to heat as the whole thing needed to be pretty hot to do a good weld.
It's a bobbin mount commonly seen on the bottom of a swinging arm,so it would be a bit away from melty bits
Has thanked: 10331 times
Been thanked: 6914 times
Gas welding can't harm anything. Arc welding has lots of leccy though.
Has thanked: 1359 times
Been thanked: 1749 times
Gas welding can harm via the heat being too close.
Lecky welding (TIG, MIG, MMA) can damage sensitive electronics so its better you disconnect that stuff if you can. Also it can damage things via the heat.
Or in other words, how much does yer ECU cost to replace?
demographic wrote: Fri Oct 21, 2022 11:08 pm Gas welding can harm via the heat being too close.
Please sir, he copied my answer.
Has thanked: 6409 times
Been thanked: 4795 times
IIRC some bloke completely fritzed the ABS on one of the LWR bikes when he leccy welded a frame part without disconnecting anything.
Good info,thanks folks.
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
If you weld a gs1150 subframe without removing the battery, you fry the abs unit, just ask Charlie or Euan!
