Battery for Total Loss Ignition
- Been thanked: 4125 times
Anyone know anything about what battery is best for a total loss ignition system on a race bike, it's got to be pretty big because I'm not bump starting an 200KG 1170 Kawasaki that I can only just reach the ground on.
- Has thanked: 10278 times
- Been thanked: 6891 times
Re: Battery for Total Loss Ignition
Just use a normal battery and have optimate style wiring to hook it up to charger at home and/or car battery at the track.
- Been thanked: 7539 times
When I raced an RD with a total loss system I just had a tray of three normal batteries with quick change bullet connectors, when the voltage started to drop, I'd swap them between races.
I was thinking of doing that, it needs to be able to run for 20 minutes, I've got rechargeable NOCO battery to start it from cold, but it needs to be able to start if I stall it, or get held up in the pit lane (it's air cooled and gets hot when stationary with the engine running)KungFooBob wrote: ↑Tue Oct 04, 2022 12:11 pm When I raced an RD with a total loss system I just had a tray of three normal batteries with quick change bullet connectors, when the voltage started to drop, I'd swap them between races.
Check the voltage.Le_Fromage_Grande wrote: ↑Tue Oct 04, 2022 1:40 pmI was thinking of doing that, it needs to be able to run for 20 minutes, I've got rechargeable NOCO battery to start it from cold, but it needs to be able to start if I stall it, or get held up in the pit lane (it's air cooled and gets hot when stationary with the engine running)KungFooBob wrote: ↑Tue Oct 04, 2022 12:11 pm When I raced an RD with a total loss system I just had a tray of three normal batteries with quick change bullet connectors, when the voltage started to drop, I'd swap them between races.
Leave it running 20 mins.
Check voltage.
Try the starter.
That'd be great if it didn't need a new battery, it'll run for 15 minutes of my NOCO battery thing after starting, you know when it's going to die because the rev counter dies before the ignition.Yorick wrote: ↑Tue Oct 04, 2022 1:47 pmCheck the voltage.Le_Fromage_Grande wrote: ↑Tue Oct 04, 2022 1:40 pmI was thinking of doing that, it needs to be able to run for 20 minutes, I've got rechargeable NOCO battery to start it from cold, but it needs to be able to start if I stall it, or get held up in the pit lane (it's air cooled and gets hot when stationary with the engine running)KungFooBob wrote: ↑Tue Oct 04, 2022 12:11 pm When I raced an RD with a total loss system I just had a tray of three normal batteries with quick change bullet connectors, when the voltage started to drop, I'd swap them between races.
Check voltage.
Try the starter.
Get a new batteryLe_Fromage_Grande wrote: ↑Tue Oct 04, 2022 1:53 pmThat'd be great if it didn't need a new battery, it'll run for 15 minutes of my NOCO battery thing after starting, you know when it's going to die because the rev counter dies before the ignition.Yorick wrote: ↑Tue Oct 04, 2022 1:47 pmCheck the voltage.Le_Fromage_Grande wrote: ↑Tue Oct 04, 2022 1:40 pm
Check voltage.
Try the starter.
Le_Fromage_Grande wrote: ↑Tue Oct 04, 2022 2:15 pm Yes, I was wondering what was the best type to buy.
I've done some research and it seems a deep cycle lead acid battery is the best way to go, lithium would work but they're easy to damage by over charging or letting them run too low.
- Has thanked: 2552 times
- Been thanked: 6262 times
Someone on my LinkedIn just became a "Lead Battery Engineer" at WAE working in Formula E.
I had to read it a couple of times
- Has thanked: 1264 times
- Been thanked: 1188 times
Is it like pencils and water?Mr. Dazzle wrote: ↑Thu Oct 06, 2022 4:54 pm Someone on my LinkedIn just became a "Lead Battery Engineer" at WAE working in Formula E.
