Binstore
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Binstore
Post by Screwdriver »
So I ran out of room and rather than build yet another shed, I made a little cupboardy unit to sit outside and specifically designed to carry those big green bins. Of which I have many. :hmmm:
Here's the plan.
Lay down a decent base first. I gave this a good flat skim of self levelling screed and I kept it low to reduce overall height. Part of the plan involves having this double up as a useable workbench or at least work surface.
Quite a straightforward base unit made from found materials (mostly found on my neighbours fence....)
I uhmmed and ahed about doors and hinges and finally went with this.
5.5mm ply which needed some serious effort to keep both flat in plane and relatively watertight. The panel just covers 5-10mm of overlap with the cabinet so I can push it tight or maybe even fit a seal around the edge. NB the above is not the final design, merely one of several iterations.
Bit of a palaver getting all those doors to line up with a 2mm shut line, the vertical hinge spacer and of course shims to keep the door reveals.
Not unhappy with the result.
Knocked up a design in Sketchup to make up some suitable catches. They just need to hold the door shut and there's no real pressure required. Initially I designed it so that the latch lever was a template for a steel copy but after the first test I was happy it would actually work as a 3d printed part in PETG.
It works.
..and is placed deliberately to apply pressure just where needed to keep the relatively flimsy doors firmly shut. Also has security options for later if required.
I aimed the design to go vertical or horizontal commensurate with the accuracy of the Wickes cheapo hinges. They are a disaster of course...
That still irks me because inside the Matrix they are of course perfect...
One other aspect of the construction is the ability for those giant bins to be pulled out like a drawer.
Not totally complete (EPDM roof is on the cards) but they are in, it is done and the binstore is now fully populated.
All that it contains had been "stored" on my kitchen floor. I hesitate to post a picture of that...
Half a ton of letterpress metal type, decanted from various "hell boxes" (that actually is a "thing" by the way) into my hoard of Nescafe Americano tubs.
I knew they'd come in handy one day.... :mrgreen:
Screwdriver
Re: Binstore
Hell box
From which I started to rescue some of the interesting type.
Anyone wanna guess why it's called a hell box?
Mind your p's and q's....
Yeah, I gave up and it sat on the lower layer of the kitchen floor storage disaster. Probably been there years....
Has thanked: 1264 times
Been thanked: 1188 times
Re: Binstore
Post by slowsider »
Helvetica?
Has thanked: 7810 times
Been thanked: 2527 times
Re: Binstore
I don't wish to be in any way critical, but is that not going to trap damp like Docca's roof space?
Has thanked: 2402 times
Been thanked: 3625 times
Re: Binstore
Wouldn't it be better to get the roofing/weatherproofing arrangements sorted out first, rather than trying to retrofit it to cover the storage units? Bad weather can turn otherwise careful planning on its head very quickly,,,
Has thanked: 10261 times
Been thanked: 6885 times
Re: Binstore
Ikea about £100
Screwdriver
Re: Binstore
Rockburner wrote: Sat Sep 24, 2022 8:04 pm I don't wish to be in any way critical, but is that not going to trap damp like Docca's roof space?
I don't know. I doubt it. It isn't hermetically sealed, the slab is damp proofed and there's nothing that would rot that's going to sit out there. I just needed it out of the way quickly.
Screwdriver
Re: Binstore
mangocrazy wrote: Sat Sep 24, 2022 9:11 pm Wouldn't it be better to get the roofing/weatherproofing arrangements sorted out first, rather than trying to retrofit it to cover the storage units? Bad weather can turn otherwise careful planning on its head very quickly,,,
Yes of course but it is already waterproof enough. If it rains, I throw a plastic sheet over it. If I leave it completely exposed, so long as the doors are shut, the only thing that happens is the top gets wet. I really needed to get everything out from under my feet so that I have space to get things done.
Good enough for now is good enough for now.
Screwdriver
Re: Binstore
Yorick wrote: Sat Sep 24, 2022 11:08 pm Ikea about £100
Yeah I already have one of those. Might have a couple come to think of it.
But I need storage for big green bins.
Has thanked: 599 times
Been thanked: 2428 times
Re: Binstore
Yorick wrote: Sat Sep 24, 2022 11:08 pmIkea about £100
And would last about 13 minutes if left out in the rain
Has thanked: 16203 times
Been thanked: 3921 times
Re: Binstore
MrLongbeard wrote: Sun Sep 25, 2022 12:08 am
10 :lol:
Re: Binstore
I do wish I had just a smidge of your skill! (And space!). I've admitted defeat and am heading to the B&Q type place on Monday with a list of measurements so they can cut the wood to size for me and all I have to do is screw it together!! :(
Has thanked: 836 times
Been thanked: 1238 times
Re: Binstore
Noggin wrote: Sun Sep 25, 2022 7:08 am I do wish I had just a smidge of your skill! (And space!). I've admitted defeat and am heading to the B&Q type place on Monday with a list of measurements so they can cut the wood to size for me and all I have to do is screw it together!! :(
That's not defeat, it's making the best use of your resources. If it was easy for me to pay slightly more and get everything already cut to size I would do.
Has thanked: 6375 times
Been thanked: 4746 times
Re: Binstore
Mussels wrote: Sun Sep 25, 2022 9:54 am
When Bunnings took over Homebase one of the first things they did (before turning the place into a pile-it-high mess of garden furniture etc) was take out the facility to get things cut to size. :(
Re Screwd's cupboard, I'm a fan of 'fit for purpose' but in my DIY terms they're waaay beyond that. :thumbup:
(In a fit of desperation and a rush for a little outside storage I once bought a couple of plastic 'outdoor store cupboards' from Homebase. They weren't watertight, got 2" of water in the bottom and quickly became luxe accommodation for the local snail population. In the skip they went, another waste of hydrocarbons. :()
Screwdriver
Re: Binstore
That is what I wold do in a heartbeat. Get the store to use their super expensive machine to make the cuts. But economies of scale, reuse of found materials and no fucking van means I gotta do what I can with whatever I have.
The superweapon is Sketchup. I use it for everything and if you'd like me to bore you to death with the many wonders of this ultra simple design program, just ask. If it works in Sketchup it will work in the real world. So you can play around with the design to your hearts content and then send it off to be cut to your precise requirements.
Has thanked: 2550 times
Been thanked: 6241 times
Re: Binstore
Screwdriver wrote: Sun Sep 25, 2022 1:33 pm If it works in Sketchup it will work in the real world.
That's not what B&Q said when I asked them to cut the wood for my Darth Vader Airship Palace with built in Laser Guns and realistic sound effects.
Re: Binstore
Why would I store my helmets outside ?
Re: Binstore
Post by slowsider »
Yorick wrote: Sun Sep 25, 2022 2:51 pm
Perhaps you should read the OP.
Re: Binstore
I'll have a look at sketchup. The main reason for change is that I did a plan that I thought would work, but it isn't quite right. Luckily the first was made out of wood I had left over from other things, so it isn't the end of the world. And I can use all the 'tops' still. So I only have to pay for some 35x35mm pieces and they don't charge a lot to cut them :D
When I bought the place I had planned to do all the conversion/DIY stuff myself, but obviously haven't been able to for the last few years and am somewhat more limited than I was last year. But I do feel better now that a couple of you have said getting the wood cut isn't defeat :D :D
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Re: Binstore
Post by DefTrap »
I have a similar bin store (housing about 10 bins, that's all the space I have, any bigger would require a bigger barn), also similarly serving as a workbench (the bins are really great heavy duty bins that my bil accidentally swiped dozens of over many years working on site at a factory plant in Devon). The bins similarly house the masses of important shite that was stopping me getting in the barn. Also similarly it was constructed mainly with the masses of odd timber you accumulate when you demolish/rebuild a house. Not throwing it away, sawn timber is expensive!
That's where the similarity ends, my design certainly wasn't done in SketchUp! It works though and the bins of shite add a degree of mass to make the bench really sturdy.
If I did it again (and I probably will do this somtime) is put a sturdier, cleaner worktop on it, I was just using what I had ...
Happy you're back to your old self Screwd. :)
