What tools for working at Harleys?
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
Eldest has managed to blow up his GPz550, which is impressive as even I have never managed to blow up a kwak 550. Anyway, for reasons best known to himself, he's went and bought a bloody Harley and as usual, muggins here will have to fix the bloody thing.
Being as it's a Yank, what spanners, sockets, Allen keys and stuff do I need to buy as I assume the usual agri spec hammers and molegrips won't work.
Has thanked: 9819 times
Been thanked: 10144 times
Re: What tools for working at Harleys?
'Tis all imperial gear you'll need. Muricans don't do that metric thing.
Get good quality,they may be well used. :lol:
Been thanked: 7526 times
Mole grips and a big hammer... same as any other bike.
If it's got tubed tyres you'll need flat head screwdrivers too.
KungFooBob wrote: Sat Jun 27, 2020 9:22 pm Mole grips and a big hammer...
That's just for the tappets,though.
Skub wrote: Sat Jun 27, 2020 9:24 pm
Do they have adjustable threaded pushrods?
You might need two pairs of molegrips.
KungFooBob wrote: Sat Jun 27, 2020 9:27 pm
Not metric molegrips now,they need to be imperial to work properly.
Has thanked: 6186 times
Been thanked: 5087 times
Hammer is already covered, so broom and shovel for bits that fall off?
You'll need to buy oil in qrts rather than litres, whatever qrts are?
And petrol only works if it's in gallons,Harley tanks don't recognise litres.
Skub wrote: Sat Jun 27, 2020 9:38 pm And petrol only works if it's in gallons,Harley tanks don't recognise litres.
...and don't get Imperial gallons confused with US gallons, or you'll need the AA to come drain the tank like when you fill up with diesel instead of petrol.
ogri
Has thanked: 1035 times
Been thanked: 224 times
Post by ogri »
If it is a newish one, will probably have hydraulic valves, no adjustment req.
Keep a spare drive belt handy, apparently some go often, others last forever.
Ignorance is bliss
Has thanked: 599 times
Been thanked: 2428 times
Mine is mix of metric and standard with a few torx thrown in too, but then it's fairly new.
This comes in handy
Nidge
Has thanked: 705 times
Been thanked: 701 times
Post by Nidge »
Depends on the age. Mine is a 1985 and all bolts are A/F, which is fine for me as I have a pretty comprehensive collection for my T140, but Harley often have some large (and weird sized) fittings- the rear wheel spindle nut is an annoying 1 and 1/8 inch (and the silencer means you’ll have to use a spanner rather than socket) and if you need to take off any of the primary drive components (clutch nut, compensator socket) you’ll be needing some big sockets 1 1/2 inch iirc
Has thanked: 7810 times
Been thanked: 2527 times
Nice strong anchor chain?
Been thanked: 2612 times
Assuming it has fuel, I'd suggest a box of matches.
Nidge
Post by Nidge »
cheb wrote: Sun Jun 28, 2020 1:09 pm Assuming it has fuel, I'd suggest a box of matches.
:x Yank Bikes Matter!
What grates with me for Harleys is that every non motorcyclist thinks every motorcyclist wants one. To me they are overly heavy, underpowered and have a really ugly engine. That, and the vast bulk of them have 2 strokes too many.
TBF though some of the above can be similarly applied to any lifestyle product, Apple and VWs come to mind.
Bigjawa
Post by Bigjawa »
Well lads, it's a bit of a moot point as it lasted 3 days before the electronics fucked up, currently in the dealership whilst they try to get their paws on the diagnostic stuff. :roll: :roll:
Better a diamond with a flaw, than a pebble without.
Lutin
Has thanked: 257 times
Been thanked: 328 times
Post by Lutin »
Nidge wrote: Tue Jun 30, 2020 11:54 am
Where's the "unlike"button when you need it? ;)
