Recommend me a 3 tonne trolley jack
- Has thanked: 15947 times
- Been thanked: 10243 times
Recommend me a 3 tonne trolley jack. Advantages/disadvantages of a low entry one?
TIA
TIA
- DefTrap
- Has thanked: 2259 times
- Been thanked: 2190 times
Re: Recommend me a 3 tonne trolley jack
I have a cheap one. Not like wish.com or anything like that but prolly off the shelf at the supermarket. Obviously I also use axle stands as I'm not mental but thinking about it they're also cheap ones from the supermarket. Belt and braces anyway.
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2428 times
https://www.halfords.com/tools/garage-w ... 57321.html
Get under low cars, solid as, but does weigh an absolute fucktonne
I have a Halfords one. From previous experience they tend to last between 6 and 10 years before the seals start leaking and I buy a new one.
Current one is a low profile which I bought to fit under a BMW iirc. They don't lift as high and this particular one won't lift the front wheels of my VW Crafter off the ground so I have to use a block of wood between jack and sill.
Thats my worry with a low entry, it wont have enough height to lift my camper up.Druid wrote: ↑Wed Aug 24, 2022 6:43 pm I have a Halfords one. From previous experience they tend to last between 6 and 10 years before the seals start leaking and I buy a new one.
Specs will usually quote max. lift so you can check if it's enough lift, but you won't need a low entry for the camper
- Has thanked: 836 times
- Been thanked: 1238 times
I bought a standard budget one as my two ton jack couldn't lift the transit high enough to remove a wheel.
It was about 4 times the size and weight of the 2 ton and apart from trying to move the thing it was perfect.
- Has thanked: 10261 times
- Been thanked: 6885 times
The mighty Duster has high ground clearance. So carry various sized wooden lumps to sit the jack on.Taipan wrote: ↑Wed Aug 24, 2022 6:48 pmThats my worry with a low entry, it wont have enough height to lift my camper up.Druid wrote: ↑Wed Aug 24, 2022 6:43 pm I have a Halfords one. From previous experience they tend to last between 6 and 10 years before the seals start leaking and I buy a new one.
I would have needed a block of wood several inches thick for the transit, every scenario I ran through in my head ended in disaster.
I always carry four 3ft planks to put under the wheels if we ever get stuck.
I lift the car with those if necessary.
- Has thanked: 9819 times
- Been thanked: 10144 times
Did Iron Bru Freak tell you where to get the planks?
From the shop that sells sky hooks and tartan paint
And that old favourite,the black iridium visor.
This is looking like the winner! Will chuck some new stands in as well.
https://www.machinemart.co.uk/p/clarke- ... trolley-j/
- ChrisW
- Has thanked: 2903 times
- Been thanked: 2052 times
I've had a Clarke jack for around 15yrs now - not that exact one, it's a little less compact. You'll not go wrong with it.
