Fast phone charging cables ?
Has thanked: 5468 times
Been thanked: 13167 times
Bit confused as i thought it was the charger and phone combo, not the actual cable that made things quicker.
Bought one of these for the van. To use for the Android Auto stuff.
Weirdly after 20s it bombs out and needs removing and re-connecting.
https://www.ebay.co.uk/itm/362939848386 ... 2063724971
Using it at home in a standalone charger it does the job, but about half the speed of my good one. (which is getting a bit knackered at the end).
So, what cable do i actually need for decent speed and connection. USB C type.
Has thanked: 604 times
Been thanked: 2470 times
Re: Fast phone charging cables ?
weeksy wrote: Fri Aug 19, 2022 10:22 am So, what cable do i actually need for decent speed and connection. USB C type.
Anker
Has thanked: 541 times
Been thanked: 7594 times
I've had cheap Chinese USB cables that couldn't keep up using Satnav, the power source was 1amp, but the cable wasn't supplying it.
I reckon any proper branded cable will do the job. Halfords will charge you a fortune for one, but you can sometimes get lucky and find good ones in Lidl/Aldi middle aisles, also near the checkouts in TKMaxx.
What power source are you using, the USB on the head unit or a ciggy lighter style USB adaptor, cos that's more likely to be the culprit.
KungFooBob wrote: Fri Aug 19, 2022 10:26 am What power source are you using, the USB on the head unit or a ciggy lighter style USB adaptor, cos that's more likely to be the culprit.
It's a USB C into a dedicated feed into the head unit. But as i say, even on the standalone 3-pin plug it works rubbish. Phone was plugged in for 2 hours and gained 30%.... on my other cable it'd go from 0% to 100% in 40 mins.
Has thanked: 6413 times
Been thanked: 4797 times
I dunno if it's relevant but if Type C is the one with the little pins I only have one and it's no more than 1ft long (it came with the Garmin watch). One charger/plug combo for a Samsung tablet, if plugged into my phone...the phone says 'fast charging' and I assumed it was the charger/plug that was different rather than the cable.
It may just be that the connector is rubbish and the pins aren't locating properly but a 2 or 3m cable will be quite lossy if it's made out of cheap wire.
Has thanked: 6239 times
Been thanked: 5120 times
MrLongbeard wrote: Fri Aug 19, 2022 10:24 am
Anker
Rude :obscene-birdiedoublered: :mrgreen:
Has thanked: 2258 times
Been thanked: 1245 times
Anker
Use a fair few Anker products, all very reliable :thumbup:
Greenman
Has thanked: 209 times
Been thanked: 403 times
Post by Greenman »
Just be careful buying cheap chargers and cables, i've had a few literally blow them selves out of the socket!
I always try and stick to own branded stuff for chargers and any good qaulity cable, the thicker the better!
Has thanked: 1876 times
Been thanked: 2177 times
We only allowed OEM stuff at our office in the days of office working...
Greenman wrote: Mon Aug 22, 2022 5:36 pm Just be careful buying cheap chargers and cables, i've had a few literally blow them selves out of the socket!
IIRC Which, or Trading Standards, bought a load of cheap chargers - most were slightly or very dodgy.
Has thanked: 1361 times
Been thanked: 1749 times
Didn't a few manufacturers get done for throttling the charging rate on non standard cables so they could sell theirs at huge markup?
Sure Apple was the main one (surprise surprise) and Samgsung as well?
Greenman
Post by Greenman »
the_priest wrote: Sun Aug 28, 2022 4:31 pm We only allowed OEM stuff at our office in the days of office working...
I always recommend OEM but some Business Managers just won't listen and want the cheaper option!
Greenman
Post by Greenman »
demographic wrote: Sun Aug 28, 2022 6:47 pm Didn't a few manufacturers get done for throttling the charging rate on non standard cables so they could sell theirs at huge markup?
IMO Crapple have built in self destruct dates on all their products. Didn't the iphone 7 have this? didn't apple even admit to it being true? i cant be fucked to google it again!
I have about 1100 ipad 4's still kicking about over about 7 campuses and a good 70%ish of them will not charge over 26% anymore, exactly 26%, all within about 6 months for all! coincidence? not IMO!
I also never forget back in 2012ish when Crapple released their VPP and DEP services to the UK. We had 2 year+ old ipads and we couldn't get them to work properly with the newly released VPP and DEP Services with our MDM (Cisco Meraki back then), we had about 270 of them in one big school. It turned out if we had ipads older than 2 years we would need to buy all new devices to use the new services, that was my first experience with Crapple!
Slenver
Has thanked: 650 times
Been thanked: 865 times
Post by Slenver »
Don't think so. The only thing similar to this was Apple & Samsung slowing down older phones with depleted batteries to stop them shutting down automatically. In theory was supposed to be 'helpful' but the issue centred around them introducing the feature without telling people. They later changed it to a switchable option in the settings.
