Calculating what fork spring rate I need
- dern
- Has thanked: 1016 times
- Been thanked: 1767 times
I have standard fork springs in my 2005 636 zx6r and on track the cable tie is pushed down to the bottom of the fork. The bottom of the tie is a couple of mm from the casting. So I'm either at or very near the end of the travel and comparing with @Tricky's bike, his ends up 10-15mm from the stanchion.
I've tried adjusting preload and it's made tiny differences but nothing dramatic to bring it up that much. The choice of springs from hyperpro is 9, 9.5 and 10N/mm where 9 is the standard. How do I know whether to go for a 9.5 or a 10? Is there some theory or calculator that tell me?
Thanks.
Thanks.
- Has thanked: 65 times
- Been thanked: 1235 times
- Has thanked: 836 times
- Been thanked: 1239 times
Re: Calculating what fork spring rate I need
Is it near or at the end? Near would mean you have the perfect spring already.
I rang k-tech for advice a few months ago and they were very helpful in advising on spring rate and oil level
- Has thanked: 9828 times
- Been thanked: 10145 times
If you can't get both static and loaded sag within the recommended settings for your weight, then spring rate will need changed.
- dern
Ok, I'll go through that process over the winter.
It doesn't feel like it's bottoming out but given that adjusting the preload had made little or no difference to the travel seems to suggest that it might be... I think.
- dern
That suggests I need 10s front and back.
Brooks suspension have this sheet... https://www.brooksuspension.co.uk/media ... e_2021.pdf
...which suggests the fronts are 8.3 by default and I need 9s and the rear is 9.5 and I need 10.5 based on a weight of 95Kg.
I'll get the tape measure out.
- Has thanked: 5451 times
- Been thanked: 13087 times
YOu don't need different springs...
You need Ohlins forks !!!!
- Has thanked: 326 times
- Been thanked: 2173 times
Whatever you do get linear springs, the hyperpros are progressive aren’t they ?
- Tricky
- Has thanked: 2565 times
- Been thanked: 2680 times
I've got 9.0s in mine- I got this with the bike along with the receipts etcdern wrote: ↑Thu Aug 18, 2022 3:55 pmThat suggests I need 10s front and back.
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
- Has thanked: 228 times
- Been thanked: 154 times
As above, also do you know what oil level and weight you have in there?
I wouldn’t be in a rush to stick stiffer springs in if not.
