BUELL-POWERED MMC SR1
Has thanked: 9839 times
Been thanked: 10155 times
Very tidy engineering work. The end result will divide opinion,but I admire the craft involved.
https://www.bikebound.com/2022/08/14/mmc-sr1/
Has thanked: 2920 times
Been thanked: 2061 times
Re: BUELL-POWERED MMC SR1
Impressive & ingenious - plus I'd happily have a go if offered.
Been thanked: 4125 times
It looks like a Lego bike
Been thanked: 2619 times
The wheels look good.
Has thanked: 6382 times
Been thanked: 4765 times
Le_Fromage_Grande wrote: Mon Aug 15, 2022 8:13 pm It looks like a Lego bike
Lego bike would have a drive belt and not a chain. The chain looks a bit out of place.
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
Nice
But it's a fragile buell
And it's tiny
Has thanked: 1350 times
Been thanked: 1726 times
Err...
I think I quite like that one.
There, I've said it.
Thankfully its a million miles away from the image of most Harleys though.
Has thanked: 2636 times
Been thanked: 1523 times
Are those frame tubes bolted to the headstock and swing arm mount?
If so, that's a lot of stress going through them. Hopefully there's more than one and the pieces don't just butt up against each other.
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
Not sold on that one at all ....... plus its a Buell which means as soon as the engine is started bits will fall off randomly due to vibration
mitch13780
Been thanked: 8 times
Post by mitch13780 »
No vibrations at all and thanks to frame rigidity all the power goes to the rear wheel
mitch13780
offered NO, but if you want the same, we can build it for you
mitch13780
The frame has been engineered. In total there are 24 bolts and the tubes go inside the front and rear block. Bike runs good
Has thanked: 6200 times
Been thanked: 5090 times
You can see how a Voxan frame provided inspiration:
