PRE-UNIT PERFECTION: RECREATING A 1950S DESERT SLED
- Has thanked: 5455 times
- Been thanked: 13103 times
- Been thanked: 7539 times
Re: PRE-UNIT PERFECTION: RECREATING A 1950S DESERT SLED
Can I get one that isn't brown and doesn't have a cream seat?
- ChrisW
- Has thanked: 2921 times
- Been thanked: 2061 times
I could live with the brown if the seat was black..KungFooBob wrote: ↑Mon Jul 25, 2022 8:20 am Can I get one that isn't brown and doesn't have a cream seat?
- Has thanked: 261 times
- Been thanked: 1266 times
It is wise to secure the brake cable away from the tyre.
Can’t see that exhaust pipe bracketry staying tight for long when you’re out sledding in the desert, either.
- Has thanked: 9841 times
- Been thanked: 10156 times
What's the current deal with brown seats/grips/paintwork?
It's not like I ever remember loads of brown bikes,aside from military vehicles.
I like the clean,simple lines of the bike,but not the colour or those straight thru pipes. That will be loud.
- Has thanked: 6382 times
- Been thanked: 4765 times
It's an interesting read and helps to understand what he was aiming for. It's not really my cuppa and it'll be waaay to loud. What's the point of building a bike to take you off the beaten track if you're going to destroy the peace and quiet when you get there? So it's a
- Has thanked: 65 times
- Been thanked: 1235 times
This is my kind of bike........buuuuuuuut did they just give up when choosing a colour scheme, and those pipes have zero leg protection from the heat. First time it gets ridden there'll be either burnt nylon stuck to them or leather/belstaff rubs.
- Been thanked: 4125 times
The exhaust routing is silly, the could have gone under the right hand side of the engine and still been higher than the frame rails, then swooped up to get the high level exit required for going through puddles (like this thing will ever get ridden off road)
Also the left hand footpeg appears to be bolted to the engine casing, it's going to vibrate like a black mamba with Duracells, and the first time you land from a jump it will break the casing. Just noticed both footpegs are bolted to the engine. Yet another edit, looks like they're mounted to the engine mounting plates - still not great.
And while I'm nit picking, the footpegs are too high and too far forward for an off road bike, that is going to be horrible to ride stood on the pegs.
Last edited by Le_Fromage_Grande on Mon Jul 25, 2022 5:10 pm, edited 4 times in total.
- DefTrap
- Has thanked: 2267 times
- Been thanked: 2193 times
- Has thanked: 2636 times
- Been thanked: 1523 times
And last time I checked a sled was wheel-less.
- Has thanked: 2552 times
- Been thanked: 6262 times
I thibk those footpeg mounting points at pretty much standard. But yes they vibrate like a dildo with duracells.
- Has thanked: 2408 times
- Been thanked: 3638 times
Or me. Can't really find anything to be positive about. There was one in similar vein a week or so ago that was far better in every way.
Sounds like the voice of experience.
Total pain in the arse i tell ya.
They look like standard Pre-unit Triumph pegs and mountings.Le_Fromage_Grande wrote: ↑Mon Jul 25, 2022 4:57 pm
There’s nowhere you could fit them that wouldn’t shake like hell anyway.
