SECOND TIME ROUND: REVIVING A ROTARY ENGINE MOTORCYCLE
Has thanked: 5455 times
Been thanked: 13103 times
Been thanked: 4125 times
Re: SECOND TIME ROUND: REVIVING A ROTARY ENGINE MOTORCYCLE
It's Wankel
Has thanked: 6382 times
Been thanked: 4768 times
LOL. The hole under the seat has migrated to under the tank!
It's interesting and some nice work on it but can't help thinking they might as well have restored it to original. Performance mods aren't exactly needed, the discs look out of place, the hipster mirrors ditto. Generally a bit :hmmm: on this one but might read a bit more about that engine.
Been thanked: 2623 times
I like it, the hole above the engine makes a change from the usual hole where the airbox used to be.
Edit: Damn you CS, and all who sail in you.
Has thanked: 4366 times
Been thanked: 2855 times
I might not need a top box if I owned that.
Rotary. Hmmm....probably won't wheelie as it rotates in the same direction as a shaft drive.
Has thanked: 15990 times
Been thanked: 10260 times
Look like they've made a good job of it, but it's not for me. I'm just too used to the look of normal engines to like it.
Has thanked: 9845 times
Been thanked: 10156 times
Heh.
It's kind of cool,however those duct tape like patches on the wheels are gash.
The rider looks really uncomfortable.
Has thanked: 2553 times
Been thanked: 6262 times
That's proper economical use of a pipe bender.
Despite it being Wankel, I actually quite like it.
Has thanked: 6201 times
Been thanked: 5090 times
Count Steer wrote: Thu Jul 14, 2022 9:48 am Rotary. Hmmm....probably won't wheelie as it rotates in the same direction as a shaft drive.
IIRC with a rotary, it is only possible in bends, to one direction.
