Techtronics Racing Adjustable QSLU2 Quickshifter £100
Screens, footpegs, helmets, leathers, boots, jackets, luggage, basically anything biking related
millemille
Has thanked: 304 times
Been thanked: 1007 times
Post by millemille »
Techtronics Racing Adjustable QSLU2 Quickshifter.
Adjustable - both triggering force and cut time - compression rod (to be clear, that means the rod is pushing the gear lever when changing up the gearbox) stand alone quickshifter. The rod can be used with any other type of quickshifter or ECU (back in the day the Foggy Petronas WSB team used Techtronics rods with their MoTeC ECU's). Rod length is 230mm eye to eye but can be shortened by 60mm by removing a machined section, the length is also adjustable more finely by screwing in or out the rose joints on either end.
The quickshifter is a stand alone unit that cuts ignition, so can be used with carbed as well as fuel injected bikes.
The main wiring harness is present but will require an understanding of vehicle electrics/principles of quickshifters to wire in (wiring diagrams and instructions and "how to" guides are available on many forums) and the isolating switch is missing (but any on/off switch can be wired in).
These are the best part of £400 new, the price reflects the condition of mine.
I bought this for use on a project bike, but after testing it I boxed it up and it has sat in my storage unit for several years. I've tested it again and it is all working as it should.
£100 delivered
Steveqn
Re: Techtronics Racing Adjustable QSLU2 Quickshifter £100
Post by Steveqn »
Hi is this still available as I could do with one of these.
Thanks Steve Q
Has thanked: 6374 times
Been thanked: 4745 times
Steveqn wrote: Thu Jul 28, 2022 10:54 pm Hi is this still available as I could do with one of these.
Thanks Steve Q
Probably worth pinging him with an @millemille
millemille
Thanks Steve Q
Sorry mate, should have updated this to say it sold.
Hi, holy thread resurrection, I'm trying to wire one of these on a mates race ZX6, does anyone have a wiring diagram for this
Ignore that, we worked it out
