427 TRACKER: A ZESTY CUSTOM YAMAHA RD400 FROM CANADA
Has thanked: 5455 times
Been thanked: 13103 times
Uh oh... i'm not sure the cheese will approve.
https://www.bikeexif.com/custom-yamaha-rd400
Has thanked: 6382 times
Been thanked: 4768 times
Re: 427 TRACKER: A ZESTY CUSTOM YAMAHA RD400 FROM CANADA
Lot of work gone into it. All the lines and angles work nicely. This one has a good reason for fitting the tyres too. :thumbup:
Love the 'Not for aircraft' on the carbs. :D
Q? IIRC the MoT checks the headlight beam (in the UK). Does the headlight actually have to have a beam? This bike just has a couple of LED bars.
Been thanked: 7543 times
It's very... clean.
Has thanked: 2553 times
Been thanked: 6262 times
Name is misleading, I was expecting a 7 litre V8.
Been thanked: 4125 times
I like it
Been thanked: 2623 times
So do I.
Has thanked: 2409 times
Been thanked: 3639 times
The engine is very high in the frame. The crank must be at least 4 inches above a line through the wheel spindles. Not sure how that would affect the handling, ditto the angle of dangle of the swingarm. And why can't people fit a side stand of the correct length?
Other than that, I like it. No pretence, just a clean minimalist look.
Has thanked: 9845 times
Been thanked: 10156 times
Le_Fromage_Grande wrote: Tue Jun 28, 2022 9:02 am I like it
mangocrazy wrote: Tue Jun 28, 2022 12:22 pm The engine is very high in the frame. The crank must be at least 4 inches above a line through the wheel spindles. Not sure how that would affect the handling, ditto the angle of dangle of the swingarm. And why can't people fit a side stand of the correct length?
I don't think the engine is high in the frame, it's more that it's got the swingarm at a stupid angle, it's not going to handle well like that.
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
Not to mention chain tension
Le_Fromage_Grande wrote: Tue Jun 28, 2022 1:12 pm
The engine is high relative to a line drawn through the wheel spindles. The engine sits 'normally' in the frame, but the suspension has been tweaked to provide more ground clearance, probably due to having both spannies on the same side. That's one of the least appealing parts of the build IMHO.
It's stupidly high for a flat tracker, a sport which doesn't need much ground clearance and the bikes only turn left.
I still like it, I wouldn't want to ride it.
Shame (again) that they don't show it being ridden so you can see how it sits when loaded. It does say in the article it's a 'street tracker' so, if the streets warrant those tyres, a bit of ground clearance may be welcome. :D
