"Understeering" on a motorbike
- Has thanked: 1924 times
- Been thanked: 1728 times
My old bus of a Speed Triple doesn't do it,
The Triumph Scrambler doesn't do it
But the Diavel - when cornering always wants to turn less then I want it to. (When I say understeer it is not the tyre breaking away and skipping over the tarmac, more it just doesn't quite want to go where I want it to - other than with a bit more leverage)
My guess is this could be a nature of the geometry of the bike, or suspension, or perhaps I just need to counter steer harder.
A quick google brings up MCN saying it is down to too soft front suspension ( which I would be surprised at)
My other solution would be to jack up the rear ride height.
Is there anything that I am missing ?
- Been thanked: 9454 times
Re: "Understeering" on a motorbike
Tyre pressures?
They are 34 front 36 back - which is more or less what the manual says ...
but good point.
but good point.
It's too light on the front - and u can shorten the wheelbase. Drop the front forks in their yokes @ approx 2mm invervals and see how she turns - max @ 6mm. It'll put more weight on the front - better grip and make it turn quicker. You could raise the rear ride height - therefore changing the geomentary putting more weight on the front but I'd put everything to std first / drop the forks and take it 1 stage at a time.
- Has thanked: 2554 times
- Been thanked: 4160 times
What size rear tyre/wheel does the Diavel have? From memory it's pretty massive. Too big a rear tyre tends to make the bike run wide on corner entry and also makes it harder to get the bike to turn.
My TL1000S was a bit like that. It had a 6" rear rim with a 190/50 tyre on as standard and behaved as I describe. I swapped the standard rim for a GSXR600 5.5" rim with 180/55 tyre and it went exactly where I wanted it to.
- Has thanked: 1080 times
- Been thanked: 1010 times
How wide are the bars compared to the other two? Is it maybe just leverage?
- Has thanked: 7585 times
- Been thanked: 5913 times
Can you get to a dealer for a ride on another bike?
Reasons could range from stuff already mentioned to "they all do that sir".
Once in a turn, if you take any pressure off the bars, does it 'sit up' and go straight?
The bars are pretty wide . Leverage gets it round - but not on the track it naturally wants to take.slowsider wrote: Sat Jun 25, 2022 3:05 pm How wide are the bars compared to the other two? Is it maybe just leverage?
However, god obviously hates me.
Just went out to use the bike to go somewhere
And I have a puncture!
Good news is it is my drive
Bad news is that no 240 rear tyres exist in the UK
According to one spec sheet I've seen online, the rear tyre is an otherworldly 240/45 ZR17...
Wider than a very wide thing and very low profile - that alone should make it steer like a barge...
I've just clocked what bike it is.
I think certain expectations need to be set when comparing turn in on a Triumph Scrambler and a Ducati Diavel...
Couchy
- Has thanked: 360 times
- Been thanked: 2246 times
It’s the bike, the geometry the tyre sizes the style. Ride with a lot of pressure on the inside bar and it’ll hold a line. Ride relaxed and with a light touch it’ll understeer like loads of cruisers do even the diavel which is one of the best.
As for the tyre mates diavel has been off the road most of the year waiting for one !
- Has thanked: 2844 times
- Been thanked: 3495 times
I was following a Diavel once and he wasn't hanging about, twisty B. Reckon you've just got to boss it about more than a speed triple.
- wull
- Has thanked: 976 times
- Been thanked: 1846 times
This but I’d recommend riding relaxed but when it comes to steering inputs for example incorporating counter steer etc you can still apply force but be relaxed, it’s when you’re not relaxed and too stiff that you won’t be able to man handle it.Couchy wrote: Sat Jun 25, 2022 8:00 pm It’s the bike, the geometry the tyre sizes the style. Ride with a lot of pressure on the inside bar and it’ll hold a line. Ride relaxed and with a light touch it’ll understeer like loads of cruisers do even the diavel which is one of the best.
Couchy
That’s what I meant, need to be a bit pro active rather than just sitting there and as you say stay relaxedwull wrote: Sat Jun 25, 2022 9:19 pmThis but I’d recommend riding relaxed but when it comes to steering inputs for example incorporating counter steer etc you can still apply force but be relaxed, it’s when you’re not relaxed and too stiff that you won’t be able to man handle it.Couchy wrote: Sat Jun 25, 2022 8:00 pm It’s the bike, the geometry the tyre sizes the style. Ride with a lot of pressure on the inside bar and it’ll hold a line. Ride relaxed and with a light touch it’ll understeer like loads of cruisers do even the diavel which is one of the best.
And allow time & distance, take off the mental pressure.wull wrote: Sat Jun 25, 2022 9:19 pmThis but I’d recommend riding relaxed but when it comes to steering inputs for example incorporating counter steer etc you can still apply force but be relaxed, it’s when you’re not relaxed and too stiff that you won’t be able to man handle it.Couchy wrote: Sat Jun 25, 2022 8:00 pm It’s the bike, the geometry the tyre sizes the style. Ride with a lot of pressure on the inside bar and it’ll hold a line. Ride relaxed and with a light touch it’ll understeer like loads of cruisers do even the diavel which is one of the best.
Slow a bit sooner, get the speed a bit lower, a little throttle open while still straight and upright so the bike is settled, grip the tank with your knees and relax your shoulders, then:
- look - point your chin where you want to go
- press - keep pressing until you get the lean angle you need
Ok, you might know all this.
But ...
The point is to go back to basics. Assuming there's nothing wrong with the bike, learn how to ride it. Take the mental 'Aaargh it won't steer' element out. Then, once it's fluid, build pace back in.
- Has thanked: 1059 times
- Been thanked: 1643 times
Never ridden a Diavel but damn nearly every 80s bike used to understeer off the throttle.
Open em up a bit and they started to actually follow a line.
That was just what they did.
It's a cruiser style bike with a ridiculously large rear tyre (twice the width of the front), so it's never going to steer precisely. There are ways to mitigate this up to a point but ultimately it's all about decisions made at the design (or more likely marketing) stage that mean it's just the way it is.
just waiting to see if I can get a new rear - going rate 230 GBP!
Allegedly available for £216.19 here:
https://www.mytyres.co.uk/search?vehicl ... eedRating=
You will need to make your own arrangements for fitting, though...
