Jody's KTM690 is it broken?
- Has thanked: 1952 times
- Been thanked: 1295 times
As some of you will be aware my 2016 KTM690 duke dumped it's oil out a few weeks ago. I finally managed to helicoil the broken thread. I've put 1.5 L of cheapo oil in (1.7L capacity) and started it up.
Bear in mind the bike has always been noisy, it is a KTM after-all! I'm not certain it's noisier. Compared to the second video, it's questionably quieter !!??
What say the RTTL minds ?
- Has thanked: 5468 times
- Been thanked: 13167 times
Re: Jody's KTM690 is it broken?
not broken.
Sorted my sound issues....
That's a normal 690 engine there.
- Has thanked: 6413 times
- Been thanked: 4797 times
Quieter! (Particularly as the first one is indoors).
Job jobbed.
Job jobbed.
They're different bikes. First is his, bottom one isn'tCount Steer wrote: ↑Sun Jun 19, 2022 4:25 pm Quieter! (Particularly as the first one is indoors).
Job jobbed.
- MrLongbeard
- Has thanked: 604 times
- Been thanked: 2470 times
If I hadn't listened to the second video I'd be concerned, but sod it, put some decent dino blood in it and go for a rip
I could go start mine up, but honestly that sounds exactly like a 690.MrLongbeard wrote: ↑Sun Jun 19, 2022 5:12 pm If I hadn't listened to the second video I'd be concerned, but sod it, put some decent dino blood in it and go for a rip
I'd be out already
Yebbut...his still sounds quieter than the second one - which I assume is a 'healthy' bike. Not that either of them sound like a sewing machine exactly.weeksy wrote: ↑Sun Jun 19, 2022 4:32 pmThey're different bikes. First is his, bottom one isn'tCount Steer wrote: ↑Sun Jun 19, 2022 4:25 pm Quieter! (Particularly as the first one is indoors).
Job jobbed.
For sure, they're not your Japanese machine for sure.Count Steer wrote: ↑Sun Jun 19, 2022 5:15 pmYebbut...his still sounds quieter than the second one - which I assume is a 'healthy' bike. Not that either of them sound like a sewing machine exactly.weeksy wrote: ↑Sun Jun 19, 2022 4:32 pmThey're different bikes. First is his, bottom one isn'tCount Steer wrote: ↑Sun Jun 19, 2022 4:25 pm Quieter! (Particularly as the first one is indoors).
Job jobbed.
Or even a Ducati.weeksy wrote: ↑Sun Jun 19, 2022 5:16 pmFor sure, they're not your Japanese machine for sure.Count Steer wrote: ↑Sun Jun 19, 2022 5:15 pmYebbut...his still sounds quieter than the second one - which I assume is a 'healthy' bike. Not that either of them sound like a sewing machine exactly.
Thanks for the feedback
I'm going to run it up to temp again, drop the cheapo oil and replace with the pukka stuff and take it out for a ride.
As far as I understand, if it is knackered it will get louder and be sluggish quite quickly !
- Has thanked: 4383 times
- Been thanked: 2867 times
Only just seen this.
That sounds like a regular 690 engine to me.
Good luck, hopefully you've dodged a bullet.
- Has thanked: 541 times
- Been thanked: 7594 times
Maybe a little bit of extra wear has helped it?
Like how bikes run in at full throttle on the dyno make more power, etc..
- Has thanked: 2572 times
- Been thanked: 6300 times
Didn't realise that I'd not updated this thread......
The 690 seemed fine with it's fresh oil and helicoiled oil filter cover.
However an abundance of disposable income and a dash of paranoia saw me ordering a brand new engine cover and gasket and a set of clutch plates. The bike and all parts were handed over to a local mechanic in the UK who put it all together for me. It's been fine since......
I have an engine management light on and the bike cut out on me twice recently. KTM dealer diagnosed Lamda sensor so I have one on order.
Then yesterday the clocks did this.....
and if that wasn't enough it also gave warnings or air tempreture sender playing up. It was 28c and it warned me to be careful of ice !!
- Has thanked: 65 times
- Been thanked: 1235 times
I seem to recall the dash being a problem spot on all the Dukes with LCD screens from 125s to 790s. Bit of a bugger. Glad the engine seems fine though.
Yeah i've seen Dash issues, but not like that, they usually crack. that looks more like something on the circuit board has burnt out inside and melted it.
