Page 1 of 4
NBD - project green track bike
Posted: Thu Jun 02, 2022 2:07 pm
by dern
To be honest there’s not a lot to do to it as far as I can see.
- E82F96E9-897F-491F-B808-076449053AF0.jpeg (525.7 KiB) Viewed 920 times
I want to try out what a 600 is like on track mainly because I want to see if it helps me progress faster. My 1000 is great sometimes and feels completely overwhelming other times so this is where the experiment begins.
As standard it’s got a slipper clutch but rear sets and a trans logic quick shifter have been added. It has an Akra Exhaust and a power commander fitted. It’s a 2006 636 by the way. Comes with R11s.
Re: NBD - project green track bike
Posted: Thu Jun 02, 2022 3:27 pm
by weeksy
That's cracking. We've been admiring @Tricky on his slightly earlier one today at Donington
Congratulations
Posted: Thu Jun 02, 2022 3:58 pm
by Dodgy69
Getting a bit common now.
Posted: Thu Jun 02, 2022 4:01 pm
by dern
Quick question, I was told that the discs are fully floating and they have play in them. Looking online I can see that this is a thing but given the safety aspect of this have I been sold a line or do these look fine…
[media] [/media]
Posted: Thu Jun 02, 2022 4:04 pm
dern wrote: Thu Jun 02, 2022 4:01 pm
[media]
[/media]
They're shagged
Posted: Thu Jun 02, 2022 4:23 pm
by dern
Got bigger issues any way. Oil leak from the back. Spoke to the seller and it’s going back. Never mind. Plan b.
Posted: Thu Jun 02, 2022 4:35 pm
by Le_Fromage_Grande
Discs are very shagged
Posted: Thu Jun 02, 2022 4:46 pm
by dern
Yep. Kicking myself for being so naive. It’s going back tomorrow and picking up the other near identical bike that I saw this morning.
Posted: Fri Jun 03, 2022 12:57 pm
by dern
It’s gone back and got my money back which is a relief.
So this is now the new project green track bike…
- F44398FA-5389-4761-89ED-FAB2EA4C437E.jpeg (460.25 KiB) Viewed 799 times
It’s very similar, same year and mostly the same kit on it but all the oil is on the inside and the discs aren’t borked.
Posted: Fri Jun 03, 2022 1:04 pm
What's NBD?
Posted: Fri Jun 03, 2022 1:25 pm
by dern
New bike day
Posted: Fri Jun 03, 2022 6:26 pm
by weeksy
dern wrote: Fri Jun 03, 2022 12:57 pm
Nah, you're pulling our legs, it's the same bike isn't it
Congratulations again, 2 new bikes in as many days, we've got some competition here
@Couchy
Posted: Fri Jun 03, 2022 7:10 pm
by Couchy
weeksy wrote: Fri Jun 03, 2022 6:26 pm
Congratulations again, 2 new bikes in as many days, we've got some competition here @Couchy
Hold my beer I’ll sort this
Posted: Fri Jun 03, 2022 8:31 pm
by dern
Heh
Posted: Fri Jun 03, 2022 8:50 pm
by Tricky
Excellent! Green ZX6s are the forum's new MT07s
So, has the blade gone?
I'll be interested to see how you get on with it- my view on difference between 600s & 1000s as track bikes FWIW is it's simply ease of use- 1000s typically allow you to be a lot lazier for any given laptime, ie less gearchanges, use a higher gear etc and pull back time easier on straights- 600s can be massive fun and very rewarding IMO, but you really need to keep them spinning at 10k+ to really enjoy them whereas on your average 1000 has more mid-range and can be easier to ride, albeit definitely not easier to use all the power, if that makes sense.
Anyway, I'm sure you know all that- happy new bike day, and look forward to catching up properly at Pembrey, if not another TD before then
Posted: Fri Jun 03, 2022 9:35 pm
by wull
Good stuff, here’s hoping it helps you progress but the main thing is to enjoy it.
Posted: Fri Jun 03, 2022 9:48 pm
by dern
Cheers all. I’m not selling the Honda. I’ll see how I go on the Kawasaki for the rest of the year and if I stop using the Honda then I’ll put it back to road trim, tidy it up a bit and probably hang on to it. I’d regret selling it just like I regretted selling the 929 I used to have.
Posted: Sun Jun 05, 2022 8:51 pm
by dern
Changed the oil and it wasn’t that clean but no nasties in it. Also changed the brake fluid which was kind of ok but flushed it all out anyway to be on the safe side.
Secured the race rear bodywork that was day on some off cuts of pipe lagging. I knew this would need doing when I bought it and the lagging was a temporary measure apparently. Anyway, made a bracket curved to support the fibreglass seat and secured the seat to it. Very happy with that.
Fitted the baffle and it changed the tone a lot and sounds quieter… we shall see I guess.
Ran it up to see if the cooling system is working and it’s all good although it takes longer than I expected to reach 100. Maybe the thermostat is stuck open a bit or maybe it’s just how they are. I’ll order a new one and deal that over sometime soon.
Connected up to the healtech quick shifter and that seems to be working. I’ll configure it when I get the gear toe peg that’s missing… vibrated off apparently on the way home from Almera.
Ordered some new toe pegs and some TWM levers. I have the same levers on the Honda and really like them. Will fit these and then should be good to go for a week tomorrow at Bedford.
Posted: Mon Jun 06, 2022 9:07 pm
by singlesman
If it’s a ex race bike has the thermostat been removed?
Posted: Tue Jun 07, 2022 10:19 am
by dern
singlesman wrote: Mon Jun 06, 2022 9:07 pm
It's possible, I'll take a look, thanks. I don't think it's a racebike as nothing is drilled for lock wire.
