A Modern Manx?
Has thanked: 9845 times
Been thanked: 10157 times
A Modern Manx?
Been thanked: 7543 times
Re: A Modern Manx?
I like it, a bit.
The pipes just look awkward tho'
Been thanked: 4125 times
Re: A Modern Manx?
Oh dear, that's a mess
Has thanked: 2554 times
Been thanked: 6262 times
Re: A Modern Manx?
Point for using an actual pipe bender.
Subtracted again for bending them into a weird shape :hmmm:
Has thanked: 6382 times
Been thanked: 4770 times
Re: A Modern Manx?
I quite like it too, apart from the pipes. I suppose it's that things should look like what they do ie remove combustion products, smoothly and efficiently, not take them on a rather tortuous trip.
Has thanked: 16240 times
Been thanked: 3938 times
Re: A Modern Manx?
KungFooBob wrote: Thu May 19, 2022 4:14 pm I like it, a bit.
Looks like they thought it would look better than crash bungs!! :lol: :lol: :lol:
wull
Has thanked: 881 times
Been thanked: 1552 times
Re: A Modern Manx?
Post by wull »
Nice 👌🏻
Has thanked: 15992 times
Been thanked: 10261 times
Re: A Modern Manx?
Headers are odd, but apart from that its gorg as they say round these parts!
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Re: A Modern Manx?
Post by Demannu »
So to take an engine cover off involves removing the exhausts!!!!
Nice apart from that.
Re: A Modern Manx?
Demannu wrote: Fri May 20, 2022 9:17 am So to take an engine cover off involves removing the exhausts!!!!
My old Triumph has very similar exhausts...you can't do very much without taking the pipes off. The best bit is, they completely block the timing inspection covers, which makes setting said timing somewhat awkward.
Has thanked: 2636 times
Been thanked: 1523 times
Re: A Modern Manx?
inewham wrote: Fri May 20, 2022 8:08 am Looks like a pair of old school crashbars from behind :)
So... you drop it... it lands on the headers... which rip the exhaust studs out of the head.
As an aside, my brother's R1250S was written off last year thanks largely to the engine protectors. He'd stopped, the van coming the other way on the single track road didn't quite make it, clipped the crash bar and ripped the mounting bolts out of the crankcases. Add in the damage caused by toppling left and it was all too much to repair.
Has thanked: 7822 times
Been thanked: 2532 times
Re: A Modern Manx?
The Spin Doctor wrote: Fri May 20, 2022 11:41 am
Any damage to the engine cases on a BM will be uneconomical to repair by a dealership because the engine cases are a substantial part of the frame.
I bet the engine protectors were after-market? Most OE-BM protection stuff might bolt to the head, but not the cases for this reason. (well - it certainly used to be that way, not sure on the really new stuff).
But that's the thing with protection bars - the force has to go somewhere.
I once dropped the Mirth- with crash-bars fitted where the crash-bars didn't bolt to the frame, but instead clamped around the lower frame rail. The impact definitely bent the frame...... it actually handled better afterwards. :D
Re: A Modern Manx?
Rockburner wrote: Fri May 20, 2022 12:58 pm Any damage to the engine cases on a BM will be uneconomical to repair by a dealership because the engine cases are a substantial part of the frame.
As far as I know it was all BMW standard stuff, but can't swear to that... he just handed them a huge wodge of cash and rode - well, wobbled - away on it. Was scary watching him struggling with it riding round the Pyrenees at walk pace.
I know the forces have to go somewhere but bolting them into the crankcases does seem a very limiting factor.
Has thanked: 2409 times
Been thanked: 3639 times
Re: A Modern Manx?
A modern Manx Norton?
No.
It's a warmed over Triumph Thruxton that some sad sack is trying desperately to associate with the Manx name.
Point one - the Manx is/was a Norton, this is a Triumph.
Point two - the Manx Norton was a single, this is a twin.
Can someone please tell me how this piece of 'association by wishing' can be allowed to stand?
Tricky
Has thanked: 2568 times
Been thanked: 2681 times
Re: A Modern Manx?
Post by Tricky »
mangocrazy wrote: Fri May 20, 2022 9:40 pm A modern Manx Norton?
No.
All very valid points which I agree with- I too found it a bit strange - it's a Triumph FFS :crazy:
Having said that though, as these sort of things go, I quite like it, silly shape header pipes aside ( which I am guessing are that shape to try and make it look more like a Manx than it would with sensible ones :D )
Re: A Modern Manx?
No.
Blimey... let's not be pendantic... we're living the dream now, you know.
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Re: A Modern Manx?
Post by DefTrap »
Better than a lot of modern interpretations.
Looks great from some angles, others not so much.
If you featured it in Classic Bike mag it'd certainly bring on a few seizures.
Has thanked: 6202 times
Been thanked: 5090 times
Re: A Modern Manx?
:D
Which means that someone had gone to equal effort to spoil the handling ;)
The Spin Doctor wrote: Fri May 20, 2022 9:30 pm
I don't know that model, but most oilhead Rs didn't have much else that could have anything bolted to it.
It's not a new issue. Some K100 crash bars bolted to the underside of the engine, potentially with similar catastrophic damage in a crash.
Scotsrich
Has thanked: 70 times
Been thanked: 549 times
Re: A Modern Manx?
Post by Scotsrich »
Been there, done that where it just pulled one bolt out the thread on the crankcase.
Seems crazy when a helicoil would repair the damage for a few quid.
But in my case I put the bike into a dealer and it was a third party insurance job.
So away it went.
Re: A Modern Manx?
But not impossible:
My RT had the small valve cover protectors, traditionally fitted after the cover has been scuffed :)
