Filling PCP Air rifle
Reburner
Has thanked: 5 times
Been thanked: 16 times
Post by Reburner »
I have a PCP air rifle which I fill from a dive cylinder type bottle. How do I know when this bottle needs refilling?
Has thanked: 316 times
Been thanked: 1078 times
Re: Filling PCP Air rifle
Post by Silly Car »
Short answer, when there isn’t enough pressure / gas left to fill the air rifle...
Or buy a pressure gauge
http://www.beaversports.co.uk/Catalogue ... gle-gauges
Depending on your set up, you might be able to add a button gauge, just make sure you get a 300 bar one if using kit rated to that level.
Ant
Has thanked: 24 times
Been thanked: 161 times
Post by Ant »
Doesn't your bottle have a gauge? Mine to. I have the quick release fittings with plugs. I can charge the plugged off fitting to see what the gauge reads, then vent it off.
