Storing A Bike Outside
- Has thanked: 2632 times
- Been thanked: 1498 times
Re: Storing A Bike Outside
Watch out for paintwork damage... outdoor covers flap in the breeze. Scratched the screen badly on the XJ6. I usually remember to pop an old pillow case over the top of the screen now.
- Has thanked: 9677 times
- Been thanked: 9700 times
If you haven't already done so,I'd remove battery,fill fuel tank and turn off tap. If it has carbs,drain them. A spoonful of oil down the plugholes might save you bother later.
Block exhaust/air intake to stop critters lodging. Smother it all with ACF50.
I'd also throw an old duvet over it before the plastic tarp and tie it all down.
- Bigyin
- Has thanked: 1418 times
- Been thanked: 2620 times
Dont you live near the sea?
If so letting air under it might not be the best. If you have no other option then make sure its covered in ACF50 (like i just noticed after posting what skub said) or some other repellent against the salt air. Might even be worthwhile moving the brake calipers off discs and wrapping them in poly bags rather than them welding themselves on.
- Bigyin
WD40 will do a job to a degree as its a degreasant and water repellent but ACF will do it better as it is from the aviation industry and 1 tin will do the job. Its only any good on metal work so use it only on that. Before you spray it pop the tin in a bucket of hot water as it help it mist better. To get to the awkward parts spray some in the lid and use a small brush to paint it on. Once sprayed it looks wet, its supposed to look like that so dont expect it to suddenly dry off. as the bike is being stored you dont have the "road crap sticking to it" problem as i have on winter commutes. The bike looks like shit but underneath its fine as the crud sticks to the ACF but a jet wash after 3-4 months riding takes it all off1888 wrote: ↑Wed Jun 10, 2020 10:43 pm Not to fussy about the tank paint as its being a rat bike when i get round to it. Oil down ports ill do as its been six month since last ran and probably another 8 now. Yeah bung up holes an intake and fill tank. Last one was showing signs of rust after a winter so been filling them ever since.
I am by the sea Bigyin and front is starting to stick. Probably best just take them off and rebuild over the winter. Will one tin of ACF50 be enough or will WD40 do the same job? I have lots of that
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
Don't forget to bung the air intake as well to stop mice getting in. You could also stick some of this in https://www.millersoils-shop.co.uk/tank-safe I stick it in the Le Mans tank to protect it over the 3 or4 months its being played with in the garage over winter.
