Hanging cycles from a shed ceiling
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
I’ve got limited space in my shed and want to maximise it.
I’ve got 2/3 cycles to store and was looking at solutions to hang them, it’s not the tallest of shed’s but I am quite short so it’s fine for me
Any ways I was looking at this https://thegiftofsunshine.org/products/ ... 9767999656 but unsure if it the best option.
Any of you lot got any clever ideas???
I ideally don’t want to be removing any bits of bike to store
- 1FFBD467-2CBC-4AED-8ADE-A2C8846C7932.jpeg (776.39 KiB) Viewed 652 times
CBR650r
- Has thanked: 6375 times
- Been thanked: 4746 times
Re: Hanging cycles from a shed ceiling
Hang 'em in a line on the back wall? If you hang 'em from the roof the space under isn't really any use.
eg.
https://www.amazon.co.uk/Storage-Garage ... s9dHJ1ZQ==
eg.
- Has thanked: 5449 times
- Been thanked: 13084 times
- Has thanked: 836 times
- Been thanked: 1238 times
I'd stick ladder hooks on the uprights unless you are desperate for storage.
- Has thanked: 1264 times
- Been thanked: 1188 times
Bar across to hang them from the saddle, like a triathlon transition area.
Like this:
https://ninefit.ie/products/moved-by-bi ... _QQAvD_BwE
Like this:
- formula400
slowsider wrote: ↑Sun Apr 17, 2022 5:13 pm Bar across to hang them from the saddle, like a triathlon transition area.
Like this:
That means I would be unable to walk through the shed I guess
CBR650r
- formula400
Got a work bench thereCount Steer wrote: ↑Sun Apr 17, 2022 3:54 pm Hang 'em in a line on the back wall? If you hang 'em from the roof the space under isn't really any use.
eg.
CBR650r
It looks pretty shallow, put it on a side wall - next to the tool cabinet/under the sockets and put the bar heater underneath?formula400 wrote: ↑Sun Apr 17, 2022 7:19 pmGot a work bench thereCount Steer wrote: ↑Sun Apr 17, 2022 3:54 pm Hang 'em in a line on the back wall? If you hang 'em from the roof the space under isn't really any use.
eg.
- formula400
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
By the time there's three bikes in there, there won't be any room to do anything in that space.
- formula400
Screwdriver wrote: ↑Mon Apr 18, 2022 9:33 am Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
Unfortunately I went as big as I could for my man cave, we have only so much garden space to lose.
CBR650r
You're not thinking outside the box - go upformula400 wrote: ↑Mon Apr 18, 2022 2:00 pmScrewdriver wrote: ↑Mon Apr 18, 2022 9:33 am Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
Or indeed down. Pop a vaulting horse next to the neighbours fence, get digging, and you could have a below ground den with a tunnel to freedom/pub.slowsider wrote: ↑Mon Apr 18, 2022 2:40 pmYou're not thinking outside the box - go upformula400 wrote: ↑Mon Apr 18, 2022 2:00 pmScrewdriver wrote: ↑Mon Apr 18, 2022 9:33 am Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
- Screwdriver
Your reasoning may be sound but sadly that does not change the dynamics of this situation. Either it is a man cave cum workshop or it is a bicycle hut. It cannot be both.formula400 wrote: ↑Mon Apr 18, 2022 2:00 pmScrewdriver wrote: ↑Mon Apr 18, 2022 9:33 am Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
If that is the maximum footprint for the building then the above comments are correct. Your only option would be to raise the whole shed up by say 3-4 feet on a brick plinth, then you might get away with hanging bicycles in there.
- Has thanked: 143 times
- Been thanked: 497 times
Pretty much this unless you can compromise on demounting the wheels, that way you’ll shorten the space but not increase the depth when stacking them together.Screwdriver wrote: ↑Mon Apr 18, 2022 6:35 pmYour reasoning may be sound but sadly that does not change the dynamics of this situation. Either it is a man cave cum workshop or it is a bicycle hut. It cannot be both.formula400 wrote: ↑Mon Apr 18, 2022 2:00 pmScrewdriver wrote: ↑Mon Apr 18, 2022 9:33 am Three bicycles in that shed? You might just as well roll them in and prop them up against the wall. Find somewhere else for the toolchest.
https://www.tredz.co.uk/.Minoura-Vergo- ... W5EALw_wcB
