More on bat flatteries
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
I bought a new battery for the Griso last summer - a Yuasa YTX 16 from Halfords. Then just before Xmas, the Griso failed it's MOT, and it's been SORNed up, while I try to source some fork bits. So it's stood for about 3 months.
I expected it to be flat. So I put it on the optimate. Zilch. The Optimate doesn't even register it is there. Ive still got the previous battery, which was knackered. The Optimate recognises that - it fails the test, but it can see it.
What's going on? Have I killed it? I know I've neglected it a bit, but should it survive that?
- Has thanked: 836 times
- Been thanked: 1239 times
Re: More on bat flatteries
I've had trouble with an Optimate charger declaring batteries dead when I didn't think they were, do you have a more basic charger you can try?
- Trogladyte
- dern
- Has thanked: 1016 times
- Been thanked: 1767 times
I bought one of these a while ago and have have some success charging dead batteries with it...
NOCO GENIUS5UK
There's a force mode that will attempt to charge a battery even with zero volts showing.
NOCO GENIUS5UK
- Ditchfinder
- Has thanked: 621 times
- Been thanked: 692 times
Trogladyte wrote: ↑Sun Apr 03, 2022 6:41 pm I bought a new battery for the Griso last summer - a Yuasa YTX 16 from Halfords. Then just before Xmas, the Griso failed it's MOT, and it's been SORNed up, while I try to source some fork bits. So it's stood for about 3 months.
I expected it to be flat. So I put it on the optimate. Zilch. The Optimate doesn't even register it is there. I've still got the previous battery, which was knackered. The Optimate recognises that - it fails the test, but it can see it.
Waves at fellow Griso owner
Can't help with the battery, had a Li-on on my Griso over past 2 winters without optimate or charge required. Laid up October - March both times and started no problem.
Is there a warranty on your battery?
- Trogladyte
I think it will be under warranty. But I wonder if they will say I didn't look after it .
- Ditchfinder
I can't see how what you have done is 'not looking after it' it's designed to be fitted to a vehicle and start it.Trogladyte wrote: ↑Mon Apr 04, 2022 12:59 pm I think it will be under warranty. But I wonder if they will say I didn't look after it .
- Has thanked: 7817 times
- Been thanked: 2528 times
- Ditchfinder
Aren't the YTX one's sealed ?
- ChrisW
- Has thanked: 2913 times
- Been thanked: 2053 times
Halfords have a fairly unconditional warranty on batteries, should be fine.Ditchfinder wrote: ↑Mon Apr 04, 2022 1:02 pmI can't see how what you have done is 'not looking after it' it's designed to be fitted to a vehicle and start it.Trogladyte wrote: ↑Mon Apr 04, 2022 12:59 pm I think it will be under warranty. But I wonder if they will say I didn't look after it .
I can't remember, but I'm pretty sure I got a Yuasa* for the K12R just before I sold it to the Priest, and it needed the acid installing.
* (not sure if it was a YTX - but I do have the box still)
- Trogladyte
Yes, it was pre filled. Its a YTX16. The YTX16-BS is the one with a bottle of acid
- Trogladyte
The bad news is that it's dead. Three different battery chargers confirm that it's not interested. It is an ex battery. It has ceased to be. It is no more.
The good news is that Halfords had cunningly sent me the receipt by email. So I had proof of purchase. And they gave me a brand spanking new one.
I'll take better care of this one. But big up Halfords.
