new oak table
formula400
Has thanked: 444 times
Been thanked: 863 times
new oak table
Post by formula400 »
me and the wife got a new oak table from John Lewis, it says it should be treated with oil "we recommend periodic oiling and oiling before first use" what should I use, I don't want a shiny finish, I also don't want to have to sand it as I have read in other places,
its a family table that a 10 month lad is going to cover in food I am guessing, am I best leaving it and then if it get horrible sand and coat in a few years ???
CBR650r :mrgreen:
Has thanked: 839 times
Been thanked: 1242 times
Re: new oak table
You don't want a shiny finish but want it to survive a small child, it's not looking good.
Danish oil to keep it safe or teak oil if said child doesn't go anywhere near it.
Beeswax might help but isn't infallible. You need to do some reading and work out what's best for you.
I'd use teak oil and keep it permanently covered with a padded, waterproof tablecloth. Did they not recommend something?
Has thanked: 1350 times
Been thanked: 1726 times
Re: new oak table
Danish oil is my to go finish and I put that onto the oak top I put on a Singer sewing machine frame table.
I never use the one with the stain cos if I ever need to re-coat it, it's simpler to do and I don't end up with twice as much stained bits and some with just one coat.
Plus I feel that oak is nice enough that it doesn't need extra colour.
Has thanked: 2249 times
Been thanked: 1243 times
Re: new oak table
Check out a brand called Osmo, best stuff we found.
We have solid oak work surfaces and also oak dining furniture along with a clumsy family, that's the only stuff that lasts and protects.
Re: new oak table
Also, if the oak is more than just a thin veneer it's not usually the end of the world if it gets surface damage, a quick go with a cabinet scraper takes it off and it can be re-coated.
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Re: new oak table
Post by Screwdriver »
I restored some oak furniture using this:
Before:
After:
Foodsafe non toxic etc.
Has thanked: 485 times
Been thanked: 1429 times
Re: new oak table
Table cloth for when child eats
Has thanked: 6199 times
Been thanked: 5090 times
Re: new oak table
If you're worried about the potential for damage from a child, get a thick cover and remove it when you want to be growned ups.
Been thanked: 7539 times
Re: new oak table
Plasti Dip it.
Peel it off when the kid moves out. Perfect table underneath.
Screwdriver
Re: new oak table
Tung oil and beeswax. Wood is beautiful, Oak is as hard as nails.
Follow instructions on the bottle, same with the wax. First time will need a few days iirc. Solid Oak table will last a lifetime if treated properly. Keep a jar with a damp rag of Tung oil for the occasional touch up. Doesn’t need much.
Has thanked: 2552 times
Been thanked: 6260 times
Re: new oak table
v8-powered wrote: Sun Mar 20, 2022 2:16 pm Check out a brand called Osmo, best stuff we found.
We use Osmo on our hardwood decking, it's good stuff.
We have a walnut/glass/carbon fibre dining table, I posted about it on the other site when I was building it. I oil it with Danish oil every so often. When I first got it I followed the advice someone gave me: Once a day for a week, once a week for a month, once a month for a year and then as you need it...some wag pointed out that sounds alot like marriage :lol:
TBF ours started out as bare wood and I'd bet something from John Lewis is already treated with something. We've had baby dazzle using it since she arrived and she's 4 now. All that oil has at least protected it! Its more satin than shiny, water just beads up on it.
formula400
Re: new oak table
Quite a lot of the John Lewis reviews say to use Osmo, but not what particular one.
Did it require any prep??? I’ve not no Intention of sanding. Also will it smell (the product that it???, the wife will nag its harmful 😂😂😂😂 )
CBR650r :mrgreen:
Re: new oak table
A pint of leopards fanny batter is what you need.
Screwdriver
Re: new oak table
formula400 wrote: Sun Mar 20, 2022 5:49 pm Quite a lot of the John Lewis reviews say to use Osmo, but not what particular one.
Osmo is just an oil/wax finish isn't it?
Re: new oak table
Our kitchen surfaces get quite a tough time as the missus doesn't use chopping boards much, so once every year or so we will sand them back. The dining room table we don't though.
We simply brush it on and then use a cloth to wipe it in, leave to dry and back to new....
Has thanked: 1264 times
Been thanked: 1188 times
Re: new oak table
Post by slowsider »
Horse wrote: Sun Mar 20, 2022 4:58 pm If you're worried about the potential for damage from a child, get a thick cover and remove it when you want to be growned ups.
Cut holes for the eyes though, or else child services will be on your case
Has thanked: 2555 times
Been thanked: 2289 times
Re: new oak table
Screwdriver wrote: Sun Mar 20, 2022 6:24 pm Osmo is just an oil/wax finish isn't it?
Osmo make a raft of different finishes, much like Ronseal do, but Osmo focus on oil/wax finishes.
I use the outdoor UV oil on the oak cladding. It is good, but way too soft for indoor use on a table. I might be inclined to use their floor oil, tough enough to walk on so a table should be fine.
formula400
Re: new oak table
Cousin Jack wrote: Sun Mar 20, 2022 10:46 pm
Cool thanks, I’ll investigate
CBR650r :mrgreen:
iansoady
Has thanked: 59 times
Been thanked: 169 times
Re: new oak table
Post by iansoady »
I'd get rid of the kid.......
Re: new oak table
slowsider wrote: Sun Mar 20, 2022 8:49 pm
But not for breathing? You're weird ... :D
