Speed triple 955i
BBB
Has thanked: 294 times
Been thanked: 79 times
Speed triple 955i
Post by BBB »
Idly browsing eBay and have found a potential 955i, highush mileage but looks well maintained from the pics.
If I decide to go and view it what sort of things should I be looking for specific to the bike?
Buyers guides online tend to be a bit generic, look at the tyres are the forks leaking etc..
Has thanked: 5455 times
Been thanked: 13103 times
Re: Speed triple 955i
Lets see it then....
Has thanked: 1829 times
Been thanked: 1469 times
Older ones have sprag clutch issues
BBB
Post by BBB »
Has thanked: 9845 times
Been thanked: 10157 times
BBB
Post by BBB »
Can you hear or identify a sprag clutch on starting? Clunk or rattle kind of noise.
Looks OK for the miles...
BBB
Post by BBB »
weeksy wrote: Fri Mar 11, 2022 11:39 am Looks OK for the miles...
That was my thought. Unless those frame covers are hiding a couple of massive dents...
Been thanked: 4125 times
Just buy it, what's the worst that can happen?
Been thanked: 7543 times
I heard the pink ones were fasterer.
BBB wrote: Fri Mar 11, 2022 11:35 am Can you hear or identify a sprag clutch on starting? Clunk or rattle kind of noise.
The starter motor may spin a lot but not turn the engine over much.
A_morti
Has thanked: 310 times
Been thanked: 568 times
Post by A_morti »
The later swingarm is Good News, as it probably means the linkage bearings were serviced at the same time, or at least replaced with good used. At the very least, you know the bolt in the swingarm came out relatively recently.
Is it just me, but...
New bars, clocks, indicators, rear sets, swingarm and frame covers = crashed.
Might be worth asking if he has the original parts in case you want to put it back to stock, if they don't have them it's deffo crashed.
Has thanked: 600 times
Been thanked: 2453 times
KungFooBob wrote: Sat Mar 12, 2022 3:33 pm Is it just me,
No, that's been down the road
BBB
Post by BBB »
I appear to be suffering a bit of budget creep...
An easy fix or potential money pit with no end in sight?
https://www.ebay.co.uk/itm/Triumph-Spee ... 635-2958-0
Taff
Has thanked: 255 times
Been thanked: 885 times
Post by Taff »
BBB wrote: Thu Mar 17, 2022 12:31 pm I appear to be suffering a bit of budget creep...
Starter motor needs replacing if it's not starting when hot.
I've had the same problem with my Tiger and the starter cost over £400 iirc. Step 1 in the maintenance manual..... To replace the starter motor, first remove the engine.
I didn't and it was fiddly as hell to do, but I managed it in the end
Has thanked: 2249 times
Been thanked: 1243 times
Taff wrote: Thu Mar 17, 2022 12:48 pm
Can also be voltage drop caused by poor quality starter cables, a common issue and upgrade on the 1050's. Also, and funnily enough as I only did this job yesterday on my ST1050, is the brushes wear on the starter motor - £30 kit resolved the issue. Starter easy to remove once the oil line is disconnected, a nightmare otherwise.
BBB
Post by BBB »
Had read about the starter issues, asked the seller if it spins when hot and it does but doesn't fire up and it does. Going to see if I can have a look at the weekend to see if it's a slow spin or possibly another issue.
Is it me, or do I remember there being issues with stick coils on these?
KungFooBob wrote: Thu Mar 17, 2022 2:27 pm Is it me, or do I remember there being issues with stick coils on these?
There was, the old / original ones let water in which sat in the plug holes causing agro / rust etc. It's the reason one of the cylinders on mine had 2 spark plug washers as one bugger down got stuck in place.
But they should be cheap enough to replace if they haven't been already.
Now if you'll excuse me I need a sit down, it's not often there's a bike thread on here that I know shit about
