GoPro session
Has thanked: 15955 times
Been thanked: 10248 times
GoPro session
Thinking of buying one of these as my old Ghost doesn't hold a charge very well now. I'd like a helmet chin mount for it too. Anyone using this set up?
Has thanked: 2635 times
Been thanked: 1523 times
Re: GoPro session
Taipan wrote: Sat Mar 05, 2022 11:11 am Thinking of buying one of these as my old Ghost doesn't hold a charge very well now. I'd like a chin mount for it too. Anyone using this set up?
How big's your chin?
Re: GoPro session
Lol, good point!:D Duly edited...
Been thanked: 7530 times
Re: GoPro session
Wouldn't it be cheaper/easier to just buy a new battery?
Has thanked: 2913 times
Been thanked: 2053 times
Re: GoPro session
I've had one for about five years - it's a cracking little camera.
It's been on bikes and bicycles, on and off road, in hot / cold / wet / snowy / dusty / underwater conditions and is still going strong.
Has thanked: 3255 times
Been thanked: 1737 times
Re: GoPro session
I've got a Go Pro Hero 9,I use it as a dashcam.The quality's great but the battery life is less than 1 hour,plus the card doesn't overwrite itself so as a result it fills up quickly.
Loads of tutorials & reviews on You Tube. .
Has thanked: 9828 times
Been thanked: 10145 times
Re: GoPro session
Is there not a risk with those camera thingies,that they very well may be used as evidence against you should you be ever found to be misbehaving?
Re: GoPro session
KungFooBob wrote: Sat Mar 05, 2022 11:45 am Wouldn't it be cheaper/easier to just buy a new battery?
its old 720p tech and just out of date quality wise.
Re: GoPro session
Skub wrote: Sat Mar 05, 2022 12:31 pm Is there not a risk with those camera thingies,that they very well may be used as evidence against you should you be ever found to be misbehaving?
It's to protect me more than incriminate me. I ride home next to London's cs3 cycle superhighway and often have near misses with bicycles cutting across as they won't wait at red lights and don't think about motorbikes filtering. Last week a guy actually came into the side of me!
Has thanked: 6191 times
Been thanked: 5087 times
Re: GoPro session
Taipan wrote: Sat Mar 05, 2022 1:04 pm
How much quality do you need?
Higher resolution will be better for registration plates, but will fill memory cards sooner. Plus, newer might have improved low light capabilities.
If you're happy to have it permanently bolted to the bike, you could hard wire to overcome battery limits. But would mean 'adapting' the waterproof case (ie drill, cable, silicone).
Re: GoPro session
These days I try not to 'misbehave',but if you do,yes it will record your misbehaviour.
I bought mine after a very near miss with a complete F**kwit cycling on a country lane almost ended up under the front of my Street Triple :shock: .
Ironic really as I'm Pro cycling & spend more time cycling than motorcycling :wtf: .
Has thanked: 484 times
Been thanked: 1427 times
Re: GoPro session
Dont stick it on your head. Its crap watching video that keeps jerking away as you turn your head for whatever reason. You will end up sticking a few funny/interesting videos up and if all jerky no one will watch it. You also run the risk if recording yourself speeding
dosruedas
Has thanked: 1 time
Been thanked: 18 times
Re: GoPro session
Post by dosruedas »
Itchy Boots uses a chin mount - currently a different one from that used for her earlier videos. Her video seems very stable despite most of it being taken on fairly rough roads.
Re: GoPro session
Well, I've ordered one and a chin mount, but It's not for making biking videos as such. It's really just to record who was doing what at what time, as interactions with cyclists and leccy scooters are becoming more commonplace.
Re: GoPro session
It’s here! Looks a lot more compact than the old Ghost one it’s replacing. Waiting on the helmet chin mount now but hopefully that’ll be here today. It did come with a handlebar mount and a load of other stuff including a tourist stick, but if I mounted it on the bike I’d forget it and leave it in there.
Re: GoPro session
I've been using the camera for a while now. I use it on a chin mount, so I can direct at anything, should the need arise. The chin mount fixes to the lid using straps around the chin bar, so not ideal as you cant close the visor fully, although it's not been an issue as I rarely do anyway.
The GoPro works well but in 4k wide view eats up the memory card quickly. So its in 1080 in medium view. The low res preview looks good enough, so I imagine the full-res would be good. I'll get round to looking at some point, but i'll probably buy a bigger SD card so I can run at 4k, as improved video quality was the original brief after all.
It doesn't record constantly, instead, it makes lots of little clips? So I guess you could lose a crucial moment? I'm not sure if that how its set up and could be changed or that's just how it is? It doesn't auto over write or give you the option to do so, which is annoying as I'd rather just charge it and record, rather than keep having to delete the files cos the "SD card is full". To delete the files through the app is time consuming and you can't "delete all"! I tend to use file explorer when its on the USB charger and delete them all there.
In summary, better vid quality than the Ghost HD by a long chalk, but more fiddly to use every day than I'd like.
Has thanked: 2248 times
Been thanked: 1242 times
Re: GoPro session
I use an 'AliExpress special' on my bike with 2 discreet cameras, front and rear, plus GPS with the tiny recorder unit placed in the little glove box on my Sprint - works really well with decent image quality. Got a fairly sizable SD card in it which probably overwrites a few times a week.
Re: GoPro session
v8-powered wrote: Mon Apr 11, 2022 2:23 pm I use an 'AliExpress special' on my bike with 2 discreet cameras, front and rear, plus GPS with the tiny recorder unit placed in the little glove box on my Sprint - works really well with decent image quality. Got a fairly sizable SD card in it which probably overwrites a few times a week.
I think that's the direction I'll end up going. :thumbup:
Has thanked: 218 times
Been thanked: 689 times
Re: GoPro session
Taipan wrote: Sat Mar 05, 2022 1:09 pm
ooer Missus!!!!
Re: GoPro session
Taipan wrote: Mon Apr 11, 2022 1:52 pm It doesn't record constantly, instead, it makes lots of little clips? So I guess you could lose a crucial moment? I'm not sure if that how its set up and could be changed or that's just how it is?
You'll not be missing any footage - it's called file chaptering and is designed to minimise footage loss in the case of data corruption by splitting it up into, if I remember correctly, 4 gig chunks.
