NBD, the Raspberry mullet. ! Specialized Status 140
- Has thanked: 5451 times
- Been thanked: 13087 times
https://www.rutlandcycling.com/bikes/mo ... N5EALw_wcB
After a discussion and an email today, i went bonkers and bought this.
83319_2 by Steve Weeks, on Flickr
specialized-status-160-2021-enduro-all-mountain-93720-52-93720-53-3-38259 by Steve Weeks, on Flickr
I've been debating one for a while, so thought "why not".....
I fancied trying the mullet thing, along with wanting a Specialized and loved the shape, colour and geometry of the Status.... So why not.. what's the worst that can happen lol. I used the chat online on Rutland and was met with "we only have 1 left in that size, it's in the MK store"... If you want it now i can lower the price a bit..
I replied with "can you throw in a set of pedals too?" he said yes and that was that..
Arrives Tues next week.
Frame - M5 alloy chassis and rear-end, Mixed wheel Trail Geometry, threaded BB,12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm of travel
Fork - FOX FLOAT 36 Rhythm, GRIP damper, two position Sweep adjustment, 15x110mm QR axle, 44mm offset, 140mm of travel
Shock - FOX FLOAT X Performance, Rx Trail Tune, EVOL Air sleeve, 2-position lever w/ LSR adjustment, 210x52.5mm
Number of Gears - 12-speed
Shifters - SRAM NX Eagle, trigger, 12-speed
Chainset - SRAM NX Eagle, DUB, 170mm
Chainrings - 32T
Cassette - SRAM NX Eagle PG-1230, 12-speed, 11-50t
Chain - SRAM NX Eagle, 12-speed
Rear Derailleur - SRAM NX Eagle, 12-speed
Bottom Bracket - SRAM DUB, BSA 73mm, threaded
Rims - Specialized 29, hookless alloy, 30mm inner width, tubeless ready
Front Hub - Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Rear Hub - Alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
Front Tyre - Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
Rear Tyre - Butcher, GRID TRAIL casing, GRIPTON® compound, 27.5x2.3"
Front Brake - SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Rear Brake - SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
Handlebars - Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm width
Grips - Deity, Knuckleduster, Black
Stem - Alloy Trail Stem, 35mm bar bore
Saddle - Body Geometry Bridge Comp, hollow Cr-Mo rails, 143mm
Seatpost - X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9mm, S2: 125mm, S3/S4: 150mm, S5: 170mm
Post Clamp - Alloy, 38.6mm
Chainrings - 32T
- Has thanked: 2870 times
- Been thanked: 554 times
Re: NDB, the Raspberry mullet. ! Specialized Status 140
Nice, happy NBD when it arrives. What's the plan for the Whyte?
That's a bloody good Qn mate. I generally don't keep things i don't need. But it could be useful to have as a 'spare' in case one bike is broken before a race weekend as it could be a game changer as none of the lads really own a bike i'd want to race on due to sizing, geometry etc...Beancounter wrote: ↑Tue Feb 15, 2022 10:16 am Nice, happy NBD when it arrives. What's the plan for the Whyte?
- Has thanked: 2156 times
- Been thanked: 426 times
Re: NBD, the Raspberry mullet. ! Specialized Status 140
Nice. So the plan is to drop a 27.5" wheel into the rear of this to Mullet it.
It comes as a mullet as standard mate.
The Status 140 is a mullet MTB meaning it has a 29" front wheel and a 27.5" rear wheel. This aims to take the benefits of both wheel sizes such as the short wheelbase and chainstays that a 27.5" rear wheel allows but with the best possible speed and traction because of the 29" front wheel. The Status won't break a sweat no matter what you throw at it.
Well I wonder as the spec sheet says 29 rims! Hence the question! Although the tyres are listed as Mullet sizings.weeksy wrote: ↑Tue Feb 15, 2022 10:39 amIt comes as a mullet as standard mate.
- Ditchfinder
- Has thanked: 621 times
- Been thanked: 692 times
Nah mate, now this is a mullet mouse sensor test online
- Has thanked: 1829 times
- Been thanked: 1469 times
Hold on ...
You mocked my BFeMAX mullet only two weeks ago !!
It may be Raspberry to you - but to the rest of us it is dusky pink / deep rose
29mm wide maybe?lostboy wrote: ↑Tue Feb 15, 2022 11:04 amWell I wonder as the spec sheet says 29 rims! Hence the question! Although the tyres are listed as Mullet sizings.weeksy wrote: ↑Tue Feb 15, 2022 10:39 amIt comes as a mullet as standard mate.
That would be interesting as it says 30mm internal width
I guess just a typo/omission
Talking someone else into a new bike is SO much fun.... i almost had you.
But instead i had ME !!!
who wants to tell @Welsh Muffin there's an Invisiframe kit on the way
Tell me, what is the justification? I was under the impression that the bond between you and the Whyte was so great that you probably took it out for dinner last night !
Whoa there, let's not bring logic into this....Mr Moofo wrote: ↑Tue Feb 15, 2022 12:56 pmTell me, what is the justification? I was under the impression that the bond between you and the Whyte was so great that you probably took it out for dinner last night !
You can have many.Mr Moofo wrote: ↑Tue Feb 15, 2022 12:56 pmTell me, what is the justification? I was under the impression that the bond between you and the Whyte was so great that you probably took it out for dinner last night !
1. Bonus and payrise figures at work today.
2. I wanted to try the 29er front end
3. I think the 29er front and overall bike may be quicker
4. I like Fox forks
5. BB height is better for some trails.
5. I fancied trying something new
That's about the gist of it really. There wasn't too much depth in there. Sure i think the Whyte is a brilliant bike... but it is massively overkill for many of the things i ride, i even think that with my skills getting better, it'll be the right bike for Southern Enduro racing, there's VERY little i ride that i think i won't be able to on the new bike. However, we'll have to find out the answer to that.
I give it a weekweeksy wrote: ↑Tue Feb 15, 2022 1:17 pmYou can have many.
4. I like Fox forks
I care less than you
If i really hate it, with the head angle it has, it'll be the lads race bike at the end of the year and i'll use the G-170.
Thing is, you never really know, until you try things. Like the Bird, it was something i wanted to try....
- Has thanked: 2942 times
- Been thanked: 1883 times
Good, good, you’re journey to the Dark Side’s one true wheel size has begun………
