Mudguard Extenders
- Has thanked: 602 times
- Been thanked: 4072 times
Mudguard Extenders
Following on from Trinity's cleaning thread (she's not touching anyone's nuts) has anyone fitted mudguard extenders, if you have do they stay stuck on, does the longer front mudguard effect the handling (longer mudguards on my Husky SM610 made it more unstable at speed)
- Has thanked: 7457 times
- Been thanked: 2401 times
Re: Mudguard Extenders
Yes, on all my Rocksters.Le_Fromage_Grande wrote: ↑Mon Feb 14, 2022 4:28 pm Following on from Trinity's cleaning thread (she's not touching anyone's nuts) has anyone fitted mudguard extenders, if you have do they stay stuck on, does the longer front mudguard effect the handling (longer mudguards on my Husky SM610 made it more unstable at speed)
Yes they stayed on (I also used the supplied screws, without any damage to the tyres whatsoever)
No - the handling was not affected in the slightest.
- Has thanked: 523 times
- Been thanked: 7242 times
I put one on my Tiger, I was worried it would fall off, didn't like the screws it came with so used black number plate screws.
- Has thanked: 5375 times
- Been thanked: 12766 times
1. Yes
2. Pyramid
3. Stays stuck, both on this and mt07. Cleaning it first is essential. How people expect it to stick to dirt is beyond me. No screws used.
4. No issues.
2. Pyramid
4. No issues.
- Has thanked: 2295 times
- Been thanked: 3381 times
1. Yes. Have them on VFR (RC30 forks, so shortie mudguard), Falco and KTM Duke 690 R
2. Pyramid.
3. Yes. But take care over fitment, follow instructions and I use screw and sticky pads
4. No problems at all. Wouldn't be without 'em.
What's stopping you? (apart from brakes, obvs...)
2. Pyramid.
- Has thanked: 4200 times
- Been thanked: 2762 times
I will probably get one. I have a pyramid hugger extension on my 690. I used the sticky pads. I cleaned the hugger properly and stuck it with loads of pads and then clamped it for 24 hrs. Still on there 2 years later.
Think I'll get a rad guard first but at somepoint will probably go for a fenda extender
- Has thanked: 1693 times
- Been thanked: 2013 times
Rad gaurd essential. Front fender extenders spoil the looks of a sexy naked I reckon. I did put one on the tracer, but not for long.
- Has thanked: 1264 times
- Been thanked: 1188 times
- Has thanked: 9506 times
- Been thanked: 9716 times
Shudder.
I'll admit I put one on a GPZ900R back in the day,I too used screws as I didn't trust the sticky stuff. Look what happened Toprak last season when his mechanic fitted one and trusted the sticky stuff.
Anyway,I think I'd rather just clean the bike than use one now.
- Has thanked: 467 times
- Been thanked: 308 times
Previous owner had stuck a Pyramid fender extender on the Tracer. It lasted for about 4k miles in my ownership, then came loose during a ride. Luckily no harm done, but I screwed it on after that. The Tracer 700 looks like a meccano set anyway, so a few more bits of metal don't hurt.
- Has thanked: 15280 times
- Been thanked: 9856 times
Hate the look of them, but they do their job and help stop your rank cases getting that peppered look from stone and grit blasting!
I've successfully fitted a few using the sticky pads, but one I fitted after cleaning the mating surfaces and leaving it overnight to set, was gone by the time I got to work. Never heard it or felt it go either?
Freudian slip there Terrapin?
