Choosing an aftermarket shock
- dern
- Has thanked: 987 times
- Been thanked: 1723 times
I've rebuilding a 1993 zxr 750 that I'll use for sunny day road riding and some track days. It will never carry a pillion and I'm about 95Kg. The shock that's on it looks knackered so I'm looking for a replacement.
I'm currently looking at Nitrons. Their NTR R1 combines rebound and compression and seem aimed at the road. Their R2 looks better but it's £720 which feels like a lot. Can anyone recommend anything different (and ideally cheaper) before I order the R2?
Thanks.
Thanks.
- Has thanked: 5375 times
- Been thanked: 12766 times
Re: Choosing an aftermarket shock
Nitron R2 is the budget shock of choice. I used to go Wilbers but they get hit with import duty now.
- Has thanked: 602 times
- Been thanked: 4072 times
I've got a YSS on my FZ750, it was £300ish, it's better than the standard shock on my GSXS, but it's not as good as the R6 shock I had on my FZR400, so I doubt if it's as good as a £700 Nitron, but it is a good shock for £300.
- Has thanked: 523 times
- Been thanked: 7242 times
I've been looking too.
The prices on the Nitron website look ok, until you spot they don't include VAT.
I'm pondering having the standard rear rebuilt with a more sensible spring. Ohlins have discontinued shocks for my GSXR, but some bloke in Italy seems to have a few NOS ones, but they're still £600.
Dunno about the ZXR, but for stuff like my 1100 people are fitting stock First Gen S1000RR shocks because they're cheap on ebay and although OEM, still better than the OEM that was fitted in the 90's. It may be that a modern ZX10 (or similar) shock will fit, check the forums and FB groups.
viewforum.php?f=44
our vendor here does discount on YSS shocks.... give him a call and tell him we sent you
The original GSXR1100N shock is a good shock, only problem with them is they have enough adjustment to fuck the handling up.KungFooBob wrote: ↑Thu Feb 10, 2022 2:28 pm I've been looking too.
- Has thanked: 7457 times
- Been thanked: 2401 times
I got a set of Nitrons for the Rockster (100% road use, 90% two-up (although she's so small she's under their pillion weight range ), occasionally with luggage) - first ride with them seemed good - but I haven't done much more than about 50 miles yet.
No amount of adjustment can make up for it being under sprung for my weight. A rebuild and a new spring seem to be the most cost affective option, but then there's no corrosion at all on my shock, it looks new.
Having seen the pics of Dern's ZXR, the shock probably looks like it's been used as an anchor.
It'd be more cost effective for you to eat less and lose weightKungFooBob wrote: ↑Thu Feb 10, 2022 2:36 pm No amount of adjustment can make up for it being under sprung for my weight. A rebuild and a new spring seem to be the most cost affective option, but then there's no corrosion at all on my shock, it looks new.
- dern
That's fair. There's evidence that it's been subjected to a fat knacker too judging by the tyre marks on the under tray.KungFooBob wrote: ↑Thu Feb 10, 2022 2:36 pm No amount of adjustment can make up for it being under sprung for my weight. A rebuild and a new spring seem to be the most cost affective option, but then there's no corrosion at all on my shock, it looks new.
- Has thanked: 9853 times
- Been thanked: 6651 times
If you can get an Ohlins, that's the way to go. Best out there and you'll be able to sell it for nearly as much.
The best shock I have ever had was a Maxton, real quality & British made by people who know British roads. Expensive, but you do get what you pay for.
From memory the ZXR 750 needed a revised shock linkage as well as a decent shock to really sort out the rear suspension. NWS used to make one.
Personally I think k-tech, Nitron and a few others are every bit as good as Ohlins nowadays.
- dern
I spoke to the guy who did the suspension work on my cbr1000rr and he's recommended the nitron too.
I had an Ohlins on 4 different GSXR1000s and it was awesome. Sold it after 7 years for £200 less than it cost.
- Has thanked: 3056 times
- Been thanked: 1628 times
I don't know about the later ZXR's,but I'm sure the first generation ZX750 H1 bikes benefitted from a revised shock linkage.
- dern
The linkage is different on the later bikes and supposed to be 'better'.Bustaspoke wrote: ↑Thu Feb 10, 2022 4:08 pmI don't know about the later ZXR's,but I'm sure the first generation ZX750 H1 bikes benefitted from a revised shock linkage.
- Has thanked: 9506 times
- Been thanked: 9716 times
Anything will be better than stock.
