Swingarm pivot plug...
- Been thanked: 7526 times
... Won't flippin' budge.
I've had the mole grips on it and a big pointy nosed adjustable, I've even had a drift on it and it doesn't turn.
I think I'm going to have to buy the castleated socket to take the outer nut off to have a better go at it.
- IMG_20220206_142540.jpg (205.72 KiB) Viewed 285 times
Re: Swingarm pivot plug...
A man on the internet said the spindle was hollow and I should knock it out from the other side.
Except my spindle isn't hollow.
I took the nut off the other side and tapped the spindle through a little to get a better grip on the plug.
Only it's not a plug, it's the head of the spindle. Must be an aftermarket blingy one.
I'm going to have to improvise with the ABBA stand now.
- Has thanked: 2550 times
- Been thanked: 6244 times
So that cap is actually the spindle? Am I reading that right?
Explains why you can't get it out at least.
Yup.
It should have a hollow spindle like this...
I assumed the chrome bit was a bung in the hole.
It's not, it's part of the spindle casting.
I'm either going to have to make my own ABBA stand adaptor with a hacksaw, or buy the ABBA kit that locates on a replacement footrest bolt, like you can see on Dern's pic he just posted...
- Has thanked: 9819 times
- Been thanked: 10144 times
Does the castellated nut not come loose?
- Has thanked: 2402 times
- Been thanked: 3625 times
I think (but I wouldn't bet the farm on it) that if you can get the castellated nut off, you should have much better access to the flats on the blingy spindle.
But I could be talking out of my chuff...
I took the nut off the other end. I then knocked the spindle through about an inch.
That's when I spotted that what I thought was a blingy plug was actually part of the spindle casting.
I'm not 100% sure what the castellated nut if for, you can remove the spindle without touching it.
Maybe it just acts as a steel bushing to prevent any wear in the alloy frame.KungFooBob wrote: ↑Mon Feb 07, 2022 7:29 pm I took the nut off the other end. I then knocked the spindle through about an inch.
