decent looking sliding vents with fly screen
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
I am after 2 vents of the shed, ideally I want sliding with a fly screen, I can't find loads in white, but does any one know where to find some in either brown/black or silver???
thanks
thanks
CBR650r
- Has thanked: 6375 times
- Been thanked: 4750 times
Re: decent looking sliding vents with fly screen
Screwfix do brown with sliding vent and fly screen and, I think, the same in silver.formula400 wrote: ↑Fri Feb 04, 2022 10:35 am I am after 2 vents of the shed, ideally I want sliding with a fly screen, I can't find loads in white, but does any one know where to find some in either brown/black or silver???
thanks
- formula400
I’ll check them outCount Steer wrote: ↑Fri Feb 04, 2022 1:18 pmScrewfix do brown with sliding vent and fly screen and, I think, the same in silver.formula400 wrote: ↑Fri Feb 04, 2022 10:35 am I am after 2 vents of the shed, ideally I want sliding with a fly screen, I can't find loads in white, but does any one know where to find some in either brown/black or silver???
thanks
CBR650r
- formula400
can't for the life of me find them.Count Steer wrote: ↑Fri Feb 04, 2022 1:18 pmScrewfix do brown with sliding vent and fly screen and, I think, the same in silver.formula400 wrote: ↑Fri Feb 04, 2022 10:35 am I am after 2 vents of the shed, ideally I want sliding with a fly screen, I can't find loads in white, but does any one know where to find some in either brown/black or silver???
thanks
how many do you think for a shed??? 14x5ft?
CBR650r
- Has thanked: 484 times
- Been thanked: 1427 times
Few in ebay also if you search adjustable vent. Your size of shed i would stick four in if they were about 10/12"
- formula400
Try...
https://www.screwfix.com/p/map-vent-fix ... 52mm/570hy
Or search on product code 570HY
Oops, that's fixed and the same one Felix found. I'll have another look. You could put a fixed with mesh on the outside and a slider on the inside?
Had another look and you're right no adjustable with mesh..
So, either add your own mesh or, as suggested, you can put a fixed on the outside and a slider on the inside.
- Has thanked: 1346 times
- Been thanked: 1722 times
Not sure this helps much but I'd call them Hit And Miss Vents.
Might help with the search and if you can't get one with the mesh you can just put mesh behind em.
- formula400
its bought more options for sure, and ive found some fly screen on amazon that can just be cut, so that's a good option.demographic wrote: ↑Sat Feb 05, 2022 6:30 pm Not sure this helps much but I'd call them Hit And Miss Vents.
now trying to work out do I really need to open close them, if I can't will they interfere with me tubular heater???
CBR650r
- Has thanked: 1264 times
- Been thanked: 1188 times
- formula400
here ones, where to place them, ive been reading that one should be high and one low.
the rear of the shed has about a gap of 40/50cm from the Fence and the right hand side is 15/20cm
thinking about the door, same place at the rear, then maybe one on each side.
CBR650r
