https://www.motorcyclenews.com/news/new ... r-control/
One of the exciting things about the introduction of electric motorcycles is that we’re still learning how to make the most of them – so there’s scope for giant leaps in performance instead of the diminishing returns we get from fine-tuning petrol engines after more than a century of continuous development.
Vancouver-based tech firm Exro is promising just such a leap with its new, patented ‘Coil Driver’ electric motor control electronics, which are due to reach limited production in the Zero SR-based XP Zero electric bike developed by Anglo-American customer builders Untitled Motorcycles.
While the XP Zero uses the frame, the battery and the motor from the stock Zero SR/F, versions that reach customers later this year will get a performance hike from the Exro Coil Driver motor controller.
Exro, which has been testing its system in a modified Zero SR/F, says that the result is a 15% increase in torque, taking it from an already impressive 140lb.ft to a whopping 162lb.ft, and a 25% boost in peak power, bringing it to more than 125hp.
The firm also says the system allows electric motors to rev higher, helping push the Zero test bike’s top speed from 124.66mph to 141.55mph.
New tech from Exro promises E-bike performance boost
- Has thanked: 5456 times
- Been thanked: 13103 times
- Has thanked: 1751 times
- Been thanked: 2089 times
Re: New tech from Exro promises E-bike performance boost
I'd like to see an electric bike at a trackday. Shouldn't be long now.
- Has thanked: 2556 times
- Been thanked: 6263 times
If people find electric motors dull god knows what they think of controllers. They're "just" a box of chips, capacitors etc.
TBF there's some properly clever stuff which goes on inside them but it probably won't excite many petrol heads.
- Has thanked: 2636 times
- Been thanked: 1523 times
It doesn't need more torque or power - it needs better efficiency and more range.
Barking up the wrong tree,
They do all gooey over Power Commanders lolMr. Dazzle wrote: ↑Fri Jan 21, 2022 9:05 am If people find electric motors dull god knows what they think of controllers. They're "just" a box of chips, capacitors etc.
