A sorted Lawson rep
Has thanked: 9848 times
Been thanked: 10163 times
A sorted Lawson rep
Which is actually used in anger.
https://www.bikebound.com/2022/01/14/elr-restomod/
Has thanked: 5456 times
Been thanked: 13103 times
Re: A sorted Lawson rep
I can see why you guys like it, but it doesn't do much for me
weeksy wrote: Sun Jan 16, 2022 5:48 pm I can see why you guys like it, but it doesn't do much for me
It's like the 70s maaaan,you had to be there. 8-)
Been thanked: 7545 times
Lets see what Cheesy has to say about it.
KungFooBob wrote: Sun Jan 16, 2022 7:26 pm Lets see what Cheesy has to say about it.
The acid test,innit.
Been thanked: 4125 times
Looks good, I'd change the exhaust and run the oil cooler hoses over the top of the engine, but yeah it's good, you can tell it's used because the forks look long, if you run modern forks On them they're too short and the bike handles like a shopping trolley.
Has thanked: 10282 times
Been thanked: 6894 times
Skub wrote: Sun Jan 16, 2022 7:24 pm
80s for Lawson ;)
Has thanked: 2409 times
Been thanked: 3639 times
I like it (in a semi-nostalgic kinda way), but that poking out crankshaft end bothers me not a little. Have an off on that side and you could easily lunch the engine. Either put some kind of protection around it, or just machine the sticky-out bit off. It's not like it's serving any purpose. I assume he's running total-loss ignition and no longer wants or needs an alternator.
He's running a standard crank with no generator or starter gear, you'd have to get a shorter crank pin made to not have that lump, which would be expensive.
Has thanked: 487 times
Been thanked: 1433 times
Its rather nice :thumbup:
Le_Fromage_Grande wrote: Sun Jan 16, 2022 10:27 pm He's running a standard crank with no generator or starter gear, you'd have to get a shorter crank pin made to not have that lump, which would be expensive.
Not as expensive as crashing, landing on it and trashing the motor.
I doubt if he's worried about the engine, they're cheap and plentiful in North America as they were used in police bikes for twenty years, I think Kawasaki USA were still making KZ1000Ps in 2002.
Le_Fromage_Grande wrote: Mon Jan 17, 2022 8:36 am I doubt if he's worried about the engine, they're cheap and plentiful in North America as they were used in police bikes for twenty years, I think Kawasaki USA were still making KZ1000Ps in 2002.
He's done a fair bit of work on the engine -" Engine rebuilt, updated, ported and polished." so I doubt he'd want to start over with an unknown munter of a motor. He's done enough to it to completely junk the alternator, shame he didn't finish the job.
