MCN MOTO MORINI X-CAPE 650 (2022-on) Review
Has thanked: 5456 times
Been thanked: 13103 times
THought i'd throw this in as it's a name that some will like... and a bike some will like too
The middleweight adventure market is hotting up with Yamaha, Aprilia and Triumph all fighting for the biggest slice of the pie and yet the Moto Morini X-Cape 650 should not be ignored.
The X-Cape is capable, practical and pleasing. It is somewhat basic, with no riding modes and it is also a little on the heavy side, but it’s a welcome £4000 cheaper than Aprilia’s Tuareg 660 and £1500 less than Triumph’s Tiger 660 Sport.
Many will be happy to have fewer bells and whistles, but more cash left in their pocket. But with a fully adjustable Marzocchi front end, Brembo brakes, Bosch ABS and Pirelli tyres as standard... there’s still a lot to like.
The Moto Morini is comfortable, boasts a decent build quality and certainly stands out from the crowd. And all for under £7000.
Where the Moto Morini X-Cape immediately stands out is when you climb aboard. Even with the taller of the two seat options (845mm or 820mm) you feel yourself nestling into the bike in a way that makes you feel at one with it, and it’s very well balanced.
This means the weight isn’t really an issue, even on gravel tracks or light trails. It’s slim and narrow just where it matters, making this a twin that thinks it’s a single in terms of its agile handling, and its carefully designed seat and flanks make it easy to ride standing up on the pegs.
It’s a genuine go-anywhere motorcycle and can tackle light off-road work without any difficulty. It will appeal to dirt-riding novices or those wanting to explore gravel trails or farm tracks.
The Morini is comfortable too, with adequate (if not exactly spacious) room for a passenger. Though the 845mm seat height may be a little tall for some shorter riders, it’s perfect for my 5ft 10in and getting both of your feet flat on the ground at a standstill is no problem at all.
Spec-wise, Marzocchi 50mm forks are fully adjustable, have 160mm of wheel travel and are set at a 25.5° rake, with a generous 123mm of trail. There’s 135mm of movement at the rear with the X-Cape’s aluminium swingarm working a direct-action KYB monoshock that’s adjustable for preload and rebound damping. Wheelbase is a rangy 1470mm.
Claimed wet weight is 232kg with the 18-litre tank at 90% capacity, which is pretty substantial compared to a full-tank Yamaha Ténéré 700 (205kg) or new Aprilia Tuareg 660 (204kg).
Though the Euro5-friendly 649cc, 59bhp parallel-twin engine needs to be revved for brisk progress, there’s a decent spread of torque. It's also made by Morini's Chinese neighbours CFMoto and acts as a stressed member in a robust-looking tubular steel frame.
The X-Cape pulls strongly from 2000rpm in sixth gear with smooth fuelling and zero transmission snatch.
There’s no trace of an abrupt pick-up from a closed throttle, just a smooth, liquid response which adds to the sense of controllability, and the X-Cape’s flawless gearshift and light clutch action make riding in traffic or off-road a breeze.
The parallel twin is torquey, free-revving and smooth, thanks to the single gear-driven counter balancer and hefty weights in the ends of the handlebars there’s no vibration at any revs, even when the needle heads towards the 10,500rpm rev limiter.
The delivery is pretty linear with a slight surge at 7000rpm. A 47bhp version is coming for A2 licence-holders, too. Because there’s still a conventional cable throttle it doesn’t have riding modes or traction control.
Moto Morini don’t have much of a presence in the UK. At the time of writing there are just three dealers, which could make servicing a bind, and none of them are carrying stock yet – although the bikes are due before long.
The X-Cape is also entering a challenging part of the market, up against some of Britain’s best-selling bikes where the competition is fierce and proven.
However, as the first Moto Morini to be developed under Zhongneng ownership the X-Cape is a simple yet effective all-round offering at a very tempting price, with a proven engine, ease of use and comfort, and decent build quality given its pricing. It looks pretty chippy too.
Don’t be put off by the slightly daft name, with decent build quality and distinctive design, the new Moto Morini is a pleasing and practical machine.
It’s reasonable value, too. Coming in at £6995, the Morini is £2500 cheaper than the best-selling middleweight adventure bike, Yamaha’s Ténéré 700, and £1500 below Triumph’s also new Tiger 660 Sport. It’s a bit like finding premium lager in that bargain-bin aisle at Aldi.
Despite the sub-£7000 price tag, the X-Cape boasts an impressive spec. The 7in full-colour TFT dash gives the bike a touch of modern class, while the tapered handlebars mounted on 60mm risers provide a commanding riding position.
Been thanked: 4125 times
Re: MCN MOTO MORINI X-CAPE 650 (2022-on) Review
The styling isn't to my taste, but it's reasonable value.
Has thanked: 2409 times
Been thanked: 3639 times
Does nothing for me, but can't argue that it's good value. It's also something of a porker - 30kg heavier than the (admittedly more expensive) competition. Styling is weird. There's a humungous gap between mudguard and fairing. And brakes may be Brembo, but they're budget sliding caliper Brembos.
Nah.
mangocrazy wrote: Fri Jan 14, 2022 12:51 pm And brakes may be Brembo, but they're budget sliding caliper Brembos.
You're not racing MotoGP on it.
weeksy wrote: Fri Jan 14, 2022 12:58 pm
Yes, I know. But I've had bikes with that kind of design brake calipers before and they are poor at best. You shouldn't skimp on brakes and tyres is my motto. The brakes don't have to be the latest radial calipers, just some decent opposed-piston design. Brembo make loads of them.
My car has sliding pin calipers, trust me the fucker stops.
Been thanked: 7545 times
Le_Fromage_Grande wrote: Fri Jan 14, 2022 1:30 pm My car has sliding pin calipers, trust me the fucker stops.
Are you poor or something?
sliding calipers... on the front!
You'll be telling me they only have one piston next!
mangocrazy wrote: Fri Jan 14, 2022 1:15 pm
But then you start adding 'this, that, the other' and you've now built a £9000 bike not a £7000 bike and no-one buys it.
Has thanked: 6383 times
Been thanked: 4773 times
Quite a lot going for that I'd say, with one big BUT....unless you live near a dealer are you really going to buy one? (Maybe that doesn't matter any more? I'm probably old fashioned as I still incline towards buying stuff where the dealer is within rock throwing distance :D I suppose you can get things serviced anywhere now and get spares off the web, but I like to be able to go and talk to/moan at/plead with an authorised dealer).
Has thanked: 10282 times
Been thanked: 6894 times
Count Steer wrote: Fri Jan 14, 2022 2:29 pm Quite a lot going for that I'd say, with one big BUT....unless you live near a dealer are you really going to buy one? (Maybe that doesn't matter any more? I'm probably old fashioned as I still incline towards buying stuff where the dealer is within rock throwing distance :D I suppose you can get things serviced anywhere now and get spares off the web, but I like to be able to go and talk to/moan at/plead with an authorised dealer).
Pick a dealer in Hawaii. Then you can have fun moaning in person :)
Has thanked: 2561 times
Been thanked: 2293 times
Way too tall for my little legs.
And that upright front style looks pants too.
weeksy wrote: Fri Jan 14, 2022 2:27 pm
To be honest I'm really not that bothered, it's not my kind of thing at all, but I really have a problem with sliding caliper designs. I get that it's selling overwhelmingly on the low cost ticket, but it would only cost an additional £20-30 to fit basic but decent opposed piston calipers.
Has thanked: 9848 times
Been thanked: 10163 times
ADV bikes make my eyes glaze over,there is nothing about any of them I like or lust after. Horrible things.
Looks like a Chinese made Multistrudel. Maybe that's what it is.
