How long do rotors last?
irie
Has thanked: 1482 times
Been thanked: 411 times
Post by irie »
Have Shimano RT-86 180mm rotors and BR-M6100 calipers.
Front brake squealed like fuck so fitted new pads. After bedding in still squealed. Took the rotor off and cleaned it - been destroyed in less than 6 months but to be fair have been blasting through a lot of shitty mud.
Been using sintered pads, will try resin pads.
Trek Fuel EX 2021
Has thanked: 5451 times
Been thanked: 13094 times
Re: How long do rotors last?
What constitutes it being destroyed?
irie
Post by irie »
weeksy wrote: Tue Jan 11, 2022 9:41 pm What constitutes it being destroyed?
Pitted and scored, don't think scotchbrite will fix it.
Edit: you can feel it when you run a fingernail over it.
Taff
Has thanked: 255 times
Been thanked: 885 times
Post by Taff »
the disks on my cannondale were down to min thickness somewhere around the 1300 miles mark.
bear in mind I'm a fat fuck, on a heavy ebike, mainly riding laps of some pretty steep singletrack (slowly)
irie wrote: Tue Jan 11, 2022 9:49 pm
Not sure that honestly means they're dead. I've had and probably still have plenty that look scored and work, fine.
irie
Post by irie »
Got a new one coming so I'll fit that with some new resin pads.
But since you reckon it's worth a try I'll use scotchbrite and afterwards a polisher to try to remove the striations. If it works then I'll owe you.
Has thanked: 2945 times
Been thanked: 1883 times
Brakes are for Astronauts and Cissies………….or is that parachutes?😂
