Leaking brake caliper
Beancounter
Has thanked: 2870 times
Been thanked: 554 times
Post by Beancounter »
my last outing on the bike was at Bike Park Wales. At the end of the day the brakes felt a little spongy, nothing too bad but I don't like a lot of lever travel so it's something I needed to fix.
Life got in the way so I only had a chance to look at the brakes last Thursday evening. To my surprise, my front caliper was leaking fluid from the top piston:
https://youtu.be/lMfwwYK32bU
Got the caliper off the bike and using the compressor was able to get the top piston out which as you can see had broken into several pieces:
Shimano Caliper 1.jpg (99.37 KiB) Viewed 267 times
Shimano Caliper 2.jpg (227.5 KiB) Viewed 267 times
Has thanked: 7819 times
Been thanked: 2529 times
Re: Leaking brake caliper
Plastic pistons? :wtf:
Beancounter
Rockburner wrote: Tue Jan 04, 2022 7:10 pm Plastic pistons? :wtf:
Yup. I’m stumped on why it broke. Also, no seals, just calliper body and piston.
£50 for a new caliper.
Taff
Has thanked: 255 times
Been thanked: 885 times
Post by Taff »
Ceramic I believe. They are known to crack and split if they aren't pushed back into the caliper square and jam, which is really quite easy to do.
Have you found a replacement yet?
I've got an old 2 pot xt caliper in the shed if that's any good for you as a temp fix.
Has thanked: 5451 times
Been thanked: 13094 times
Shimanos leak at the calipers. It's not uncommon
TBH at £50 for a complete caliper I wouldn't worry about it.
Beancounter
Taff wrote: Tue Jan 04, 2022 7:25 pm
Thanks Taff but I’ve got a new caliper on order, should be here by the weekend.
weeksy wrote: Tue Jan 04, 2022 7:42 pm Shimanos leak at the calipers. It's not uncommon
Genuinely never heard that before. Must say, it’s not a comforting thought that it’s not uncommon.
Le_Fromage_Grande wrote: Tue Jan 04, 2022 8:43 pm TBH at £50 for a complete caliper I wouldn't worry about it.
Agreed, stacking the bike into a tree would be a lot more expensive.
Beancounter wrote: Tue Jan 04, 2022 10:04 pm
Ping your start post up on STW and see the reaction :D you'll be shocked how many complain about leaky calipers. :banana-wrench:
Beancounter
weeksy wrote: Wed Jan 05, 2022 8:18 am
:shock: Kinda regretting buying another Shimano caliper - I thought mine were leaking because of the cracked piston.
thing is... there's MILLIONS of Shimano calipers out there in the world... and 'some' have issues... but it's handfuls, not 50%...
I wouldn't worry.
Taff
Post by Taff »
weeksy wrote: Wed Jan 05, 2022 10:17 am thing is... there's MILLIONS of Shimano calipers out there in the world... and 'some' have issues... but it's handfuls, not 50%...
I wouldn't worry.
Exactly this, the number of reported failure is going to be tiny compared to the numbers out there in the wild.
From what I can tell, all makes of MTB brake calipers have their weaknesses whether that's in reliability, power, feel, fade, pad rub etc.
Has thanked: 1829 times
Been thanked: 1469 times
Buy Hope - you know it makes sense
Beancounter
Mr Moofo wrote: Wed Jan 05, 2022 1:04 pm Buy Hope - you know it makes sense
If only I could justify them. :(
