PLAYFUL ENGINEERING: A DUCATI BOBBER FROM MACHINE 1867
- Has thanked: 5504 times
- Been thanked: 12764 times
- Has thanked: 15620 times
- Been thanked: 9855 times
Re: PLAYFUL ENGINEERING: A DUCATI BOBBER FROM MACHINE 1867
What, no block tread tyres? What is this world coming too!? It's one of those bikes that I like to look at the engineering that went into it, but i'd never want to own.
- Has thanked: 2612 times
- Been thanked: 6017 times
Why did they give it those two cup holders? You can't use em on a bike.
- Has thanked: 10119 times
- Been thanked: 6650 times
- Has thanked: 1788 times
- Been thanked: 1408 times
Why do you build something that is just a trinket.
Wouldn't you make it at least run so you can ride it down to The Bike Shed for a cafe latte and a vegan brownie?
Some people fish, some people play golf, some people build bikes like this. Hobby innit. But, like you, I think they should at least be capable of propulsion!
- Has thanked: 9693 times
- Been thanked: 9710 times
It's a non runner,so can only be judged on aesthetics. On that basis alone it entertains me.
- G.P
- Has thanked: 2113 times
- Been thanked: 1310 times
No chance of running for more than a float chambers full without a pump. On 90'd Ducati supersports (Where that motor came from), the fuel pump is in the tank so they could have used the same method that the factory did.inewham wrote: ↑Mon Jan 03, 2022 10:28 am I'd be more impressed if it ran
"Edi admits that the system isn’t perfect, and plans to add a fuel pump too at some point."
You can follow the fuel line from the front left of the tank to the carb so there is no evidence of a fuel pump but the carb fuel inlet is higher than the tank so gravity feed wont work (also it has no float chamber on the side which you would need for gravity feed)
Vacuum operated fuel pump would probably have sorted it, and its not exactly like they're big and hard to hide, so it does seem an odd thing to leave out?
