LED lights for a shed
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Right, currently looking at lighting options for the shed.
What’s good??? It’s 15x5ft
I want to be able to work/see in there, it has minimal natural light.
So……. What are my options? It’s hooked up to the mains
Also any recommendations on a good tubalar heater to keep the chill at bay.
CBR650r :mrgreen:
formula400
Re: LED lights for a shed
CBR650r :mrgreen:
Has thanked: 9819 times
Been thanked: 10144 times
I have two led striplights in the garage,they are very bright,much better than the old fluorescent that used to be there.
formula400
Skub wrote: Sun Jan 02, 2022 5:22 pm I have two led striplights in the garage,they are very bright,much better than the old fluorescent that used to be there.
Like what I linked or something different?
CBR650r :mrgreen:
formula400 wrote: Sun Jan 02, 2022 5:41 pm
Similar or the same as these in your link.
https://www.tlc-direct.co.uk/Products/GLPRCLED.html
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
I have loads of led striplights. They're cheap as chips and if you have a few with simple plugs then they make cheap 'work lights' for decorating etc
formula400
Skub wrote: Sun Jan 02, 2022 5:46 pm
Would I have 2 running the length of the shed or what??? A few going across?
Is there a calculation to work out how many per square foot?
CBR650r :mrgreen:
Has thanked: 599 times
Been thanked: 2428 times
I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
Similar to https://www.novelenergylighting.com/lum ... 55ksf.html so I imagine 2 is plenty for wee shed.
If not just make sure you get ones which are daisey chainable so you've only got to run a new wire from one light to the next if you want to add more
formula400 wrote: Sun Jan 02, 2022 5:16 pm Also any recommendations on a good tubalar heater to keep the chill at bay.
Image2020-12-21_01-43-51 by MrLongbeard, on Flickr
5 foot, 300 watt, costs about a quid a day to run, from https://www.wearetubularheaters.co.uk/s ... with-plug/
Don't expect them to warm the space up unless you're going to get 4 of 'em, but just that one keeps the damp at bay for me.
Has thanked: 836 times
Been thanked: 1238 times
I have a 20W LED strip light either side at the front of my double garage, I find them plenty bright enough to work in the middle with power tools. Having two is probably more important than ultra bright so you don't get much shade where your are working.
I say 20W but I'm doubting that now as my fittings look exactly the same s MrLongbeard's.
Has thanked: 7814 times
Been thanked: 2527 times
Following.
Has thanked: 218 times
Been thanked: 689 times
MrLongbeard wrote: Sun Jan 02, 2022 8:43 pm I've got 2 55W LED Tri-Proof Light - 6ft (1800mm) Length - IP65 - 5000K in a standard sized garage and they put out more than enough light.
You didnt use a spirit level when you built the garage, then?
formula400
MrLongbeard wrote: Sun Jan 02, 2022 8:47 pm
Brilliant, not needed for warmth but like you, just incase
CBR650r :mrgreen:
formula400 wrote: Mon Jan 03, 2022 11:16 am
You'll need to be mindful where you mount it / them, they get bloody hot to the touch so you don't want to be brushing against it or have stuff hanging / draped over or to close above
Has thanked: 484 times
Been thanked: 1427 times
MrLongbeard wrote: Sun Jan 02, 2022 8:47 pm 2020-12-21_01-43-51 by MrLongbeard, on Flickr
If anyone got in to nick your bike would taking the wheel off not render that chain useless as it looks like it could be dropped out and wheel put back on? Being a garage i dare say you will supply the tools also.
Felix wrote: Mon Jan 03, 2022 4:15 pm If anyone got in to nick your bike would taking the wheel off not render that chain useless as it looks like it could be dropped out and wheel put back on? Being a garage i dare say you will supply the tools also.
It's a possibility, however I have stacked the deck in my favour;
1, No I wouldn't supply the tools as I don't have an imperial socket big enough to fit the spindle yet.
2, They'd also have to remove the fender, it is solid steel not plastic, but they could use my tools for that
3, They'd have to man handle a 300+ kg bike about to do it
4, I live in a low crime area
5, All 3 of my neighbours are retired and there always at last one of them in
6, 2 of 'em have outside cameras
7, If I'm away for a day or 3 there's another chain on the back wheel
8, It's alarmed
9, There's a Honda Civic parked in front of the door
10, I have a noisy gravel driveway
You pay's your money and take's your chances, and I reckon my solution is better than a small chain that would fit through the frame.
Out of all of worries that we face on a daily basis, running out of beer gets more thinking time than being concerned my bike is going walkies
formula400
MrLongbeard wrote: Mon Jan 03, 2022 11:52 am
Good to know, I assumed they would get to hot. I’ll have to have a think as it’s quite small abs sod it burning down
CBR650r :mrgreen:
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
Screwfix have got LAP led battens on offer at the moment.
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
formula400 wrote: Sun Jan 02, 2022 5:16 pm Right, currently looking at lighting options for the shed.
I have a single one similar to the ones you linked and its sufficient for my 12 X 8 foot shed. As others have said the new LEDs put out a lot more light than old fashioned strip lights ;)
If i remember i'll have a look tomorrow for the rating on it
formula400
Bigyin wrote: Wed Jan 05, 2022 8:59 pm
Been having a look, screw fix do some Decent ones, so potentially going with a small 2/3ft one at the back over the work bench and a 5/6ft going down the centre of the shed
CBR650r :mrgreen:
