Removing nut from brass bushing
Deadpool2
Has thanked: 294 times
Been thanked: 68 times
Post by Deadpool2 »
I have managed to try and unscrew a nut fsrim a brass bushing. Unfortunately the nut and brass bushing formed an intimate love match, bonded and all I succeeded in doing is getting the bushing free of the plastic.
So now the nut and bushing rotate together.
Any easy way of removing this and fitting a new bushing, before I go to a dealer. Apparantly I need some blind rivets.
Thanks
Has thanked: 261 times
Been thanked: 1265 times
Re: Removing nut from brass bushing
Bushes aren’t usually made from brass.
Deadpool2
Post by Deadpool2 »
OK well whatever it is, it bonded together
Has thanked: 218 times
Been thanked: 689 times
Drop it in some vinegar.
Has thanked: 2405 times
Been thanked: 3630 times
A photo of the offending part(s) might help folk to understand better what you're trying/hoping to do...
ace llani
Has thanked: 30 times
Been thanked: 37 times
Post by ace llani »
Deadpool2 wrote: Sat Jan 01, 2022 10:01 pm I have managed to try and unscrew a nut fsrim a brass bushing. Unfortunately the nut and brass bushing formed an intimate love match, bonded and all I succeeded in doing is getting the bushing free of the plastic.
Thanks
You sorted with this?
Guess it's a brass threaded insert in plastic?
Usually brass, - more expensive material that steel, but easier to tap which offsets this.
Is the screw brass?
Pictures would help.
