APRILIA RS640-R CORSE
- Potter
- Has thanked: 2216 times
- Been thanked: 4613 times
- Has thanked: 532 times
- Been thanked: 7242 times
Re: APRILIA RS640-R CORSE
It's got a lot of ground clearance. I thought you were supposed to keep the weight low in a race bike.
- Has thanked: 2325 times
- Been thanked: 3380 times
I imagine it's a bit of a lean angle monster. I seem to recall reading that having weight too low causes the front to push and makes it less keen to turn. But I may be completely wrong...
- Has thanked: 10119 times
- Been thanked: 6651 times
Aye, it's all a bit complex.mangocrazy wrote: ↑Tue Dec 28, 2021 6:53 pm I imagine it's a bit of a lean angle monster. I seem to recall reading that having weight too low causes the front to push and makes it less keen to turn. But I may be completely wrong...
Was it Spencer's NR500 that had the fuel tank in the belly pan and it sloshing messed up the handling?
And also the fuel will be used in the race creating different CofGKungFooBob wrote: ↑Tue Dec 28, 2021 7:02 pm Was it Spencer's NR500 that had the fuel tank in the belly pan and it sloshing messed up the handling?
Yes, it was the first of the V4 2T racers where the engineers decided to throw accepted practice out of the window. Seem to recall he used the older triple quite a lot that year. They went back to 'normal' the year after.KungFooBob wrote: ↑Tue Dec 28, 2021 7:02 pm Was it Spencer's NR500 that had the fuel tank in the belly pan and it sloshing messed up the handling?
- Has thanked: 2612 times
- Been thanked: 6017 times
Throw it out of the window and win = visionary.
Throw it out of the window and don't win = don't know what you're doing.
