Wood Burner Chimney.
Has thanked: 10263 times
Been thanked: 6885 times
The missus wants a wood burner, but it will take up a whole wall, which is a bit silly.
I wondered if it could be taken out after the cooler nights to leave the wall clear for summer and put the chair back.
Does the flue have to be permanently sealed? Or can it come apart somehow?
Ta :)
Has thanked: 6187 times
Been thanked: 5087 times
Re: Wood Burner Chimney.
From the pics you've posted, the island isn't exactly covered with trees. Bit of a waste to burn those you do have.
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
Yeah you can remove them for the summer, they're normally just an interference or gasket fit between stove and flue. If you're set on a wood stove rather than pellet just make sure the flue is tall enough, it needs to draw.
Your main problem wit moving stoves is that theyre effing heavy.
DefTrap wrote: Mon Dec 13, 2021 7:04 pm Yeah you can remove them for the summer, they're normally just an interference or gasket fit between stove and flue. If you're set on a wood stove rather than pellet just make sure the flue is tall enough, it needs to draw.
Coolio. It's only once a year ;) And we've got a proper chappy gonna fit it all for us :)
