Pizza oven build
go_slow
Has thanked: 20 times
Been thanked: 31 times
Pizza oven build
Post by go_slow »
I've wanted a pizza oven for a while but at £500 for just the oven I had a hard time justifying it. Then this appeared down the road from me for £200, you can see why.
But you can see in the bottom picture there is insulation poking out so this seems to be a well made oven. The inside looks good so its either been heated up too quickly from new or the weather has got to it. The inside is sound so it'll just need rendering.
Plan is to build a lattice frame from 4x4 oak beams, put 8 slabs on top of that (in two layers so it becomes a 1200mm x 1200mm) base and put the oven on top of that. Then render the lot. The oak beams are seconds but for this that doesnt matter. and having it open at the front means I can store timber underneath. Managed to rent a engine hoist locally to get the oven out of the van
Has thanked: 599 times
Been thanked: 2428 times
Re: Pizza oven build
go_slow wrote: Fri May 15, 2020 10:27 am I've wanted a pizza oven for a while but at £500 for just the oven I had a hard time justifying it. Then this appeared down the road from me for £200, you can see why.
Nope I can't see diddly old chap
Has thanked: 5449 times
Been thanked: 13084 times
I can see them, not sure if it's a good thing
Has thanked: 9819 times
Been thanked: 10144 times
Just a little blue box with a question mark.
If I copy the photo address into a new tab i get;
Information
The selected attachment does not exist anymore
go_slow
Post by go_slow »
weeksy wrote: Fri May 15, 2020 12:26 pm I can see them, not sure if it's a good thing
Given the state of it probably not :crazy:
go_slow
Post by go_slow »
Getting it out of the van was interesting.There is no easy way to get it into the garden, the side alley isnt wide enough and the back of the garden is 400mm above the road. So first thing was to hoist it onto wheels
I then strapped it down in the back of the van and reversed up to the garden, I used two sheets of ply and built a bridge to the back of the country. I then wheeled it over that into the garden. I dont have any pictures of that cause I wanted to get it into the garden as quickly as possible.
And thats where it sits. As ever I used this project to buy more tools because why not. Ryobi 355mm cut off saw.
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
Looking forward to this!
BTW, you can pretty much tuck an ooni oven under your arm, no need for any of this lifting equipment... :D
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
Looks ok, I'd no idea they cost so much! Depreciation pretty tragic though. ;)
Does yours have a door?
go_slow
Post by go_slow »
Silly Car wrote: Fri May 15, 2020 2:19 pm Looking forward to this!
Yeah, I wasn't really in the market for a pizza oven. I'd wanted one for ages but wasn't really fussed to be honest. It's only that this came up locally and the timing was spot on since I'd cleared stuff out and almost finished the smoke House that I went for it. And then the oak beams coming up so cheap, seemed ordained
DefTrap wrote: Fri May 15, 2020 4:38 pm Looks ok, I'd no idea they cost so much! Depreciation pretty tragic though. ;)
Yeah, not cheap at all. And second hand ones dont come up very often since once bought they are built in as such. No, no door but as I understand it from this type (chimney at the front) any old bit of metal stood up at the front will work since the air flow flow draws up and out and not out off the front. I'm sure I'll overengineer something when the time is right!
DefTrap
Post by DefTrap »
Yeah I made an oven from scratch, a door makes it more useful. Just need to find an offcut of really heavy gauge metal. My experimental wooden one obviously didn't really have the longevity ...
go_slow
Post by go_slow »
Bit delayed on this due to work and other projects but I got the base for the oven built at the weekend. There is an upright to go at the back to support the chimney and roof. Thats the 100mmx100mm oak beams (which were crap on closer inspection which explains why they were so cheap) and 2 layers of 600mmx600mm slabs on top. Since I have to render the oven anyway I figured I would skim the slabs as well so that should tidy it up.
Big lift of the oven at the weekend.
Middle timber shows what I was dealing with. Flat top and bottom but warped in one axis. That will be the back piece, the curve will make that upright look good.
go_slow
Post by go_slow »
Took some time off this week since I needed a break so decided to get on with the oven a bit more.
Preparing for the lift.
Onto the slab.
I then hoisted up the front so I could slip the plywood out. It being balanced on the edge also allowed me to nudge it into place. I'm glad I went for a large platform for it since that gives me room to place food thats going in or has come out.
go_slow
Post by go_slow »
Last step for this part was to put the upright in place, this will support the chimney and the roof. This is the really bent piece, figured that wouldnt matter for this application.
go_slow
Post by go_slow »
So next job with oven in place was to patch it and let it dry. I did this waith normal skim cost (1 part lime, 1 part cement and 4 parts sand). Not the greatest job but it cleaned up fine so I then had to leave it to this weekend to do anything else.
go_slow
Post by go_slow »
Next job was to put a roof on it. I wanted that to float so I used catenary wire to support the roof top and bottom.
The cover the roof and add the chimney. I made a paper template for the chimney and cut it out to fit over the dome, that worked quite well.
go_slow
Post by go_slow »
Finish on he roof,put some flashind round the pipe and give it the first coat of paint
How big is the hole for pizza?
go_slow
Post by go_slow »
weeksy wrote: Sun Jun 07, 2020 5:16 pm How big is the hole for pizza?
Its 13 inches wide, the high point is 7 inches which slopes to 5 at the side which means my cast iron panes and roasters will also fit in there.
go_slow
Post by go_slow »
So yeah, been an interesting build, I've enjoyed it. Total cost not including tools bought for the job which will be used on other jobs is £673.19. Considering the pizza oven I was looking at (and thats just the oven, not the base or anything) was £550 I'm more than happy with this.
Only issue I have is how to fix the door to the front. The door I got is meant to be built in when you build an oven, you can see the tabs sticking out which would be placed between bricks or mortared into place. I dont have that luxury, and the front of the oven is concrete which is hard as so I cant screw it in place. I tried to stick it in place with fire cement but that didnt stick.
Any ideas? Thanks.
