How bikes work
- dern
- Has thanked: 1018 times
- Been thanked: 1786 times
How bikes work
This is a cool video on how bicycles, and therefore motorcycles, work in terms of steering and counter steering...
- Has thanked: 6383 times
- Been thanked: 4775 times
Re: How bikes work
Counter steering? Never heard of it.
Spin and Hoss may be along shortly.
(Someone did a similar thing with a motorbike to prove that no amount of body shifting and 'peg weighting' will get a bike to deviate from a straight line. The steering was free to move but the rider was holding dummy bars).
- Has thanked: 2556 times
- Been thanked: 6263 times
- Has thanked: 10284 times
- Been thanked: 6896 times
- wheelnut
- Has thanked: 908 times
- Been thanked: 1002 times
Re: How bikes work
It was Keith Code’s No BS (body steer) bike.Count Steer wrote: ↑Tue Nov 30, 2021 5:11 pm Counter steering? Never heard of it.
This isn’t the original vid - can’t find that one
[media] [/media]
- Has thanked: 6205 times
- Been thanked: 5091 times
Re: How bikes work
Only if it's a straight line between there and here.Count Steer wrote: ↑Tue Nov 30, 2021 5:11 pm Counter steering? Never heard of it.
- Been thanked: 4125 times
Re: How bikes work
Then how do unicycles steer?Count Steer wrote: ↑Tue Nov 30, 2021 5:11 pm Counter steering? Never heard of it.
Or bikes wheelieing for that matter?
Re: How bikes work
You counter steer aggressively to initiate the turn with rear wheel steering on a dirt bike.
Re: How bikes work
I neglected to copy the details when it was on LinkedIn. Someone doing research on motorcycle chassis / handling / whatever contacted a US racer who explained that, when sliding the rear, directional control was still by countersteering.Le_Fromage_Grande wrote: ↑Tue Nov 30, 2021 10:13 pmYou counter steer aggressively to initiate the turn with rear wheel steering on a dirt bike.
Re: How bikes work
If you Spin the wheel enough, it will eventually break to one side. Then you're awayLe_Fromage_Grande wrote: ↑Tue Nov 30, 2021 10:13 pmYou counter steer aggressively to initiate the turn with rear wheel steering on a dirt bike.
- Has thanked: 498 times
- Been thanked: 650 times
Re: How bikes work
Don't worry about all that counter steering bollocks, just gan it up on t'back wheel.
- Has thanked: 326 times
- Been thanked: 2173 times
Re: How bikes work
What I’ve always found odd is these days is instructors are obsessed with counter steering so much so it’s like you can’t learn without knowing about it.Yes we all do it as physics dictates it’s needed but I’d never heard it mentioned until some time in the early 2000’s, by then I’d been riding nearly 25 years Road, off-road and track. I still never deliberately do it turning into corners but I do use it to sit the bike up on corner exit on track, not really a technique needed on the road though as you shouldn’t be on the gas that hard
- Has thanked: 5456 times
- Been thanked: 13103 times
Re: How bikes work
@Couchy Do you do it on MTBs. ? I'm curious as i'm trying to work on it in terms of technique on the MTB and push the inside bar harder in corners.Couchy wrote: ↑Wed Dec 01, 2021 8:03 am What I’ve always found odd is these days is instructors are obsessed with counter steering so much so it’s like you can’t learn without knowing about it.Yes we all do it as physics dictates it’s needed but I’d never heard it mentioned until some time in the early 2000’s, by then I’d been riding nearly 25 years Road, off-road and track. I still never deliberately do it turning into corners but I do use it to sit the bike up on corner exit on track.
Re: How bikes work
Nope not deliberately, but I do lean on inside bar in a corner same as on a motorbike, it’s not a deliberate push at start of corner though and it’s only a gentle weighting.weeksy wrote: ↑Wed Dec 01, 2021 8:05 am@Couchy Do you do it on MTBs. ? I'm curious as i'm trying to work on it in terms of technique on the MTB and push the inside bar harder in corners.Couchy wrote: ↑Wed Dec 01, 2021 8:03 am What I’ve always found odd is these days is instructors are obsessed with counter steering so much so it’s like you can’t learn without knowing about it.Yes we all do it as physics dictates it’s needed but I’d never heard it mentioned until some time in the early 2000’s, by then I’d been riding nearly 25 years Road, off-road and track. I still never deliberately do it turning into corners but I do use it to sit the bike up on corner exit on track.
Tbh the most fun is exiting a corner on track on a big bike, running to outside of track a hard push on the outside bar as you grab the brittle sits the bike upright very quick onto the fat part of the tyre....I miss that not having a fast. Ike or doing much track time
- Been thanked: 7545 times
Re: How bikes work
And bees.
Or is it dragons?
Re: How bikes work
Your timescale is good for this.Couchy wrote: ↑Wed Dec 01, 2021 8:03 am What I’ve always found odd is these days is instructors are obsessed with counter steering so much so it’s like you can’t learn without knowing about it.Yes we all do it as physics dictates it’s needed but I’d never heard it mentioned until some time in the early 2000’s, by then I’d been riding nearly 25 years Road, off-road and track. I still never deliberately do it turning into corners but I do use it to sit the bike up on corner exit on track, not really a technique needed on the road though as you shouldn’t be on the gas that hard
Historically, almost all rider training in the UK has been based on police techniques and ex-police riders had the influence, whether L or advanced.
The old format police manual (superseded in 1996) didn't mention it at all. DSA as was didn't agree with it even being mentioned.
All that had to change in 2010 when the Mod 1 test, with the 'swerve' exercise, was introduced.
From my perspective, I want people to:
- be aware of it (many were not when I was more active in training up, to 2008). Many of those were car drivers, for them it was totally counter intuitive.
- know a simple method: press left, go left; press harder steer quicker; press more lean more; release the pressure when you have enough lean.
- be consistent. For those non-intuitive riders, if they're not then they won't use it when they need to (swerving, changing line in a bend, etc.).
FWIW the UK's omission of steering is unusual. At an event I attended there were demos by French, Dutch, US and German (or Austrian) instructors of their own steering training. That was in 1995.
Re MTB. We had a back to biking trainee, years ago, who came back after specifically to tell us how it had improved his cycling. IIRC he did some sort of downhill racing.
- Has thanked: 7824 times
- Been thanked: 2532 times
Re: How bikes work
IIRC I heard about counter-steering from police riders (family friends) when I was learning .... So about 1990-ish.
I don't know if they were taught it, or were just aware of it from previous experience, (bikers first, then coppers).
It may also be that my father (raced in the 50s/60s) knew about it as my memory is that he was aware of counter-steering too, but not as an "official" thing, just something faster riders did so you copied them.
