Recommend me a chain lube.
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
My 10yo (at least) can of Silkolene has finally ran out. What's the best one about these days? TIA.
Has thanked: 9828 times
Been thanked: 10145 times
Re: Recommend me a chain lube.
Chainsaw oil works for me,but I don't use the bike during salty roads weather.
If you got 10 years out of a can,I'd buy another!
Has thanked: 599 times
Been thanked: 2442 times
Wurth Dry Lube.
Although truth been told I've not needed any for a few years now and things may have changed :thumbup:
Has thanked: 5451 times
Been thanked: 13087 times
MrLongbeard wrote: Mon Nov 29, 2021 4:44 pm Wurth Dry Lube.
Same here...
Has thanked: 1746 times
Been thanked: 2085 times
Druid
Has thanked: 276 times
Been thanked: 898 times
Post by Druid »
It's what I use too. I understand it's not so good if you ride in the rain though.
Has thanked: 2248 times
Been thanked: 1242 times
Druid wrote: Mon Nov 29, 2021 7:24 pm
That's true, I ruined a nearly new chain in a short period in that manner. Scottoiler loaded with chainsaw oil these days....
Been thanked: 7530 times
Sell anything with a chain and just use the Pan, simples.
What ever I'm using because it's obviously the best thing ever, otherwise I might be a fool for buying such a big can of it, but not having tried hundreds of others I shouldn't really be commenting.
And how do people measure whether a chain lube is any good when they don't keep bikes long enough for the chains to wear?
Has thanked: 2551 times
Been thanked: 6245 times
Being dirty is what kills a chain. They're nominally fully sealed and self lubing so there is not a huge amount of extra lubrication required.
Has thanked: 15955 times
Been thanked: 10248 times
I'm currently using up old engine oil through the TUTORO, but after seeing that video about chain lubes, i'll go with ep80 after I've used up ols oil supplies, or for any future chain driven bikes I buy.
dern
Has thanked: 1016 times
Been thanked: 1767 times
Post by dern »
I use a light brushing of the nearest oil to me in the garage when I'm doing the job. Literally anything will do.
Has thanked: 218 times
Been thanked: 689 times
Chain? How quaint.
I believe I may have one of those on the BSA, I will have a peek.
Has thanked: 4360 times
Been thanked: 2851 times
In the last 10 years I've used Castrol racing lube and 1 can of Wurth dry lube. Plus a bit with a Tutoro
The Wurth get's rave reviews but I found I couldn't tell how much was on the chain or when it needed redoing. At times it's totally dry by the time you've spun the chain...so did I do that bit or not? So I ended up using more and more often. I also found dust stuck to it quite badly so fair amount of cleaning needed. Hardly any fling even if you ride about 10 mins after applying.
So I went back to the Castrol which dries to the touch quickly but you can still see it's there. So less needed, less often. Dust sticks to that too though as like the Wurth it's a bit tacky. Hardly any fling even if you ride about 10 mins after applying.
Tutoro I just couldn't get on with. It was feast or famine. At 1/10 turn from closed (recommended is half turn open) it'd start flicking onto the business part of the tyre within 45 mins. But not lube the inner section of the chain enough at all. So the outer would be fine but the inner not. But then I'd have to turn it down as oil on the tyre isn't for me. I suspect at half a turn open the inner would have been fine but good knows what the back tyre would have looked like. Other's use these without issue so maybe the 690's vibes making it spit more out?? It works with vibration rather than like the Scottoilers.
So I'm back to Castrol. It's not perfect but the one I'm happiest with. No idea if it's better than others or not.
Fortnine did a test of all lubes and said EP80 gear oil was best. I'm guessing you get some fling with gear oil though?
Leopards fanny batter.
Supermofo wrote: Wed Dec 01, 2021 11:14 am I'm guessing you get some fling with gear oil though?
Flings the dirt off dunnit? ;)
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Post by Trinity765 »
I use used engine oil. I put the bike on an Abba stand, dip an old toothbrush in oil and run it over the chain, bottom, top and sides. If I want to make it look really nice I'll then go over the sides of the chain with a cloth.
Benefits of using old engine oil - it's free
The problem with using old engine oil - it splatters on the back wheel rim which isn't really a problem as it rubs off easy with a cloth.
Has thanked: 10265 times
Been thanked: 6886 times
Trinity765 wrote: Wed Dec 01, 2021 12:32 pm I use used engine oil. I put the bike on an Abba stand, dip an old toothbrush in oil and run it over the chain, bottom, top and sides. If I want to make it look really nice I'll then go over the sides of the chain with a cloth.
Ditto.
Nasty stuff for your epidermis,with prolong use.
KungFooBob wrote: Wed Dec 01, 2021 11:16 am Leopards fanny batter.
Best from a Snow Leopard
