Done
Large Whyte E150S - Bosch Gen 4 625wh battery.
Owned from new July 2020 - Charger manuals and original paperwork included.
Forks have been upgraded with 170mm internals
Rear suspension has Whyte Shape it Link
Tyres are Specialized Butcher Black Diamond and tubeless
Chain and Cassette new 400 miles ago
Always maintained well, never jet washed always hand cleaned
1570 Miles.
Some marks and scratches from use.
Bank Transfer Only on collection.
Standard Spec :
COLOUR Matt Gun Metal Black/Rose
FRAME 6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal BBX Cable Routing for Dropper Post and 12mm X 148mm Boost Dropouts
FORK RockShox Yari RC 27.5", 150mm Travel, 42mm Offset, DebonAir, Motion Control RC Damper, Fast Black Coating, Tapered Steerer, 110mm x 15mm Boost, Maxle Ultimate
REAR SHOCK RockShox Deluxe Select + RT, DebonAir, Fast Black Coating, Adjustable Rebound, 2 position compression adjustment
HEADSET FSA No. 57E Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Sealed Cartridge Bearings
REAR HUB Alloy, E-bike specific, Double Sealed Cartridge Bearings, 12mm x 148mm Boost Through Axle, 32 Hole
FRONT HUB Alloy, Double Sealed Cartridge Bearings, 15mm x 110mm Boost Through Axle, 31mm Torque Caps, 32 Hole
SPOKES DT Swiss Champion 2.0mm, Black Stainless, Brass Nipples
RIMS WTB KOM Trail i30 TCS 2.0 System, Sleeved Joint, Super Tough Construction, Tubeless Ready, 32 Hole
SHIFT LEVERS SRAM X01-E Eagle, Single Click, MMX, 12 Speed
FRONT MECH N/A
REAR MECH SRAM GX-E, Single Click, MMX, 11 Speed
CASSETTE SRAM XG-1150 Eagle, 10-42, 11 Speed
CHAIN SRAM Eagle, 12 Speed
CRANKSET SRAM EX1, 165mm, ISIS with X-SYNC 2, Direct Mount 34T for Bosch Gen 4, Black
BOTTOM BRACKET N/A
SEATPOST Crank Bro High-Line 3, 30.9mm, M/L 150mm Travel, High-Line Ball Socket Remote Lever
SADDLE Whyte Custom, Triple Panel Design
HANDLEBAR Whyte Custom 6061 Alloy, 30mm Rise, 35mm Bar Bore, 780mm Wide
STEM Whyte Enduro Stem, 35mm Bar Bore, 35mm Extension
GRIPS Whyte Lock-on V Grip
BRAKES FRONT SRAM Guide GE, 4 Pot with Sintered Metal Pads, 200mm Rotor
BRAKES REAR SRAM Guide GE, 4 Pot with Sintered Metal Pads, 200mm Rotor
BRAKE LEVERS SRAM Code R, MMX
