Page 1 of 1
RJ45 cable question, conecting 2 devices
Posted: Wed Nov 24, 2021 9:49 am
by formula400
Right, not that clued up here, but ill try and explain.
So we moved into a new build, all the bedrooms have an arial socket and an RJ45 socket, so you can plug the TV straight into the internet. guessing as wired is better than WIFI, anyways in the living room I have 1x RJ45 socket, currently I have that plugged into the BT TV box (only has 1 RJ45 in put), but id like my TV to be wired, rather than wifi (wifi is decent) not sure if there are benefits to having it wired but I think it might be more reliable and stable??
also might be handy as ill be able to connect my wahoo KICKR with a wired connecting as well,
ive had a google and can for the life of me find an RJ45 cable with 2 heads, do I get a splitter box and plug that into the wall and have one going from the TV and one from the BT box??
cheers
hope that makes sense.
Re: RJ45 cable question, conecting 2 devices
Posted: Wed Nov 24, 2021 9:57 am
by Ditchfinder
Posted: Wed Nov 24, 2021 9:58 am
You need a network switch.
Something like this.
https://www.argos.co.uk/product/8495459 ... lsrc=aw.ds
You connect the socket to one port, then plug the devices into two of the other ports.
Posted: Wed Nov 24, 2021 9:59 am
Guess what the first google result is when you search for "5 port network switch"
Posted: Wed Nov 24, 2021 10:21 am
by Silly Car
I’m not sure, but you probably need a 5 port network switch, try Argos ;)
Posted: Wed Nov 24, 2021 11:36 am
by Ditchfinder
Or if you have an old network router knocking about you can repurpose that as a switch too.
https://www.howtogeek.com/174419/how-to ... rk-switch/
Posted: Wed Nov 24, 2021 11:51 am
by Le_Fromage_Grande
Get a switch, you can get RJ45 splitters, you'd need one at each end of the cable, as 100 Mbps uses 4 of the 8 wires in the cable, so you can use 4 wires for one connection and the other wires for the other connection, but they're a lot shit, so don't do it.
Posted: Wed Nov 24, 2021 1:11 pm
Pardon my higgerance but when you say switch, clearly it's not a physical switch, how does it split the signal/traffic so that multiple devices work at the same time?
Just interested like. :hmmm:
Posted: Wed Nov 24, 2021 1:20 pm
Count Steer wrote: Wed Nov 24, 2021 1:11 pm Pardon my higgerance but when you say switch, clearly it's not a physical switch, how does it split the signal/traffic so that multiple devices work at the same time?
Each device has a network card which has a hardware address (MAC), the switch has a table of the MAC addresses and which port they're connected to and sends data for that MAC to the appropriate port.
https://en.wikipedia.org/wiki/Network_switch
Posted: Wed Nov 24, 2021 1:31 pm
Le_Fromage_Grande wrote: Wed Nov 24, 2021 1:20 pm
Cheers! Makes more sense as a 'switch' rather than 'splitter' now (have actually heard of packet switching before but didn't know stuff about MACs being involved).
Posted: Wed Nov 24, 2021 1:38 pm
Before switches were as common, hubs used to be used. They provided the same connectivity, but sent the traffic to all ports and only the device that wanted it accepted, unlike the switch that only sends it to the port with the right MAC connected.
Posted: Wed Nov 24, 2021 1:58 pm
KungFooBob wrote: Wed Nov 24, 2021 1:38 pm Before switches were as common, hubs used to be used. They provided the same connectivity, but sent the traffic to all ports and only the device that wanted it accepted, unlike the switch that only sends it to the port with the right MAC connected.
You've reminded me of a small group that used to work in some labs that I was involved with (this is going back a fair amount of time...early 80s iirc). They were a bit 'boffiny' and had this demo of various appliances (lights etc) plugged into a mains circuit. They'd send a signal via the mains supply and an appliance would go 'ahah! That's for me' and the light would come on or whatever. They were v proud and had a little model of a train carrying something for each item....but I did wonder what it had to do with gas supply. :D
Posted: Wed Nov 24, 2021 2:02 pm
Count Steer wrote: Wed Nov 24, 2021 1:58 pm
Sounds like frequency division multiplexing, ethernet over mains works via the same way, you can look it up on Wikipedia if you want to know how it works, I did a BT course on it in the late 80s, by which time it had mostly been replaced with Time Division Multiplexing, which is now also defunct.
Posted: Thu Nov 25, 2021 12:52 am
by formula400
wow, never thought this would be so intense.
excuse my ignorance but what's the difference between the https://www.argos.co.uk/product/8495459 ... lsrc=aw.ds
and this
https://www.electricaldirect.co.uk/prod ... aNycGzNB70
Posted: Thu Nov 25, 2021 5:11 am
by wheelnut
An Ethernet cable has 8 cores, 100mbps only uses 4 of those cores, so a splitter will allow you to use the other 4 cores for a second device. You need one at both ends though.
Don’t do it that way though, get the switch below and a few of the patch leads
The switch is more of a traffic management device for the network. You need a switch.
Take a patch lead from the wall socket and plug it in to the switch (doesn’t matter which port). Take another patch lead and plug one end into the switch and the other end into your BT thing. Take another lead and plug it between the switch and TV.
Then another lead between the switch and any other device you want to use a wired connection for.
Posted: Thu Nov 25, 2021 11:04 am
by formula400
wheelnut wrote: Thu Nov 25, 2021 5:11 am An Ethernet cable has 8 cores, 100mbps only uses 4 of those cores, so a splitter will allow you to use the other 4 cores for a second device. You need one at both ends though.
Brilliant, thanks for that. I’ll get them ordered
