Pulleys, cleats and ropes - climbers / sailors / bdsm-ers
Has thanked: 146 times
Been thanked: 498 times
Post by Silly Car »
I am looking to hoist my various ladders up against the garage roof joists / ceiling and wondered if anyone could point me in the right direction.
Ideally, I’m seeking a self locking/latching solution which can be remotely latched/unlatched/ mounted within reach. Rough arse diagram below:
[attachment=0]E0F88907-DF3D-427E-B95B-55BD86C303F5.jpeg[/attachment]
I’m suspecting the simplest solution of two ceiling mounted pulleys and a simple cleat screwed to the wall will be the way to go but thought I’d check with the intelligentsia here first ;)
Has thanked: 1264 times
Been thanked: 1188 times
Re: Pulleys, cleats and ropes - climbers / sailors / bdsm-ers
Post by slowsider »
Lidl occasionally have bicycle storage sets which might suit your purposes.
Like this: https://www.ebay.ie/itm/263838636986?ha ... 3838636986
Has thanked: 1829 times
Been thanked: 1469 times
so you want a cleat? Any boat chandlers
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
Or even hardware stores - both pulleys and cleats were used for old fashioned clothes drying arrangements.
Post by Silly Car »
Thanks, I think the cycle ones would be too lightweight to handle ladders hanging over the cars unless I could find a means to support the ladders at both ends while in situ.
I have found this
but can seem to find any further information.
Post by slowsider »
Has thanked: 6382 times
Been thanked: 4763 times
Amazon has one for ladders, bikes, canoes good for 30kg. Some moans about delivery though but you could easily make one if you got the bits.
https://www.amazon.co.uk/Ladder-Ceiling ... 6&psc=1
LOL. I'm slower than Slowsider. :lol:
Has thanked: 2552 times
Been thanked: 6260 times
Quite impressed by your 90ft tall garage if I'm honest.
Those amazon links are literally just pulleys and cleats in convenient kit form right?
Post by Silly Car »
Mr. Dazzle wrote: Wed Nov 24, 2021 2:48 pm Quite impressed by your 90ft tall garage if I'm honest.
2.7m :D
GuzziPaul
Been thanked: 195 times
Post by GuzziPaul »
The angle you have your first pulley will tend to pull the ladders backwards off your pivot point. You need to be pulling straight up rather than backwards. You could just use a long ratchet strap, mounting the ratchet at shoulder height, making your own wide pulleys from broom handle and plastic pipe.
Has thanked: 2555 times
Been thanked: 2290 times
GuzziPaul wrote: Wed Nov 24, 2021 9:35 pm The angle you have your first pulley will tend to pull the ladders backwards off your pivot point. You need to be pulling straight up rather than backwards. You could just use a long ratchet strap, mounting the ratchet at shoulder height, making your own wide pulleys from broom handle and plastic pipe.
The pin on the diagram, if used between the top and 2nd rung, should stop the ladder slipping forward or backward more than a few inches.
GuzziPaul
Post by GuzziPaul »
But how do you get the ladder over the pin to install or remove the ladder? I have a length of thick ratchet strap webbing at the far end of the garage. I slide my ladders into it and through by a couple of feet which supports the entire ladder at an angle, I can then stand on my garage stool and slide the other end into a similar arrangement it the foot end by slide the ladders back.
Has thanked: 16232 times
Been thanked: 3931 times
Loving that you added BDSM-ers into the title :lol: :lol: :lol: :lol:
Has thanked: 218 times
Been thanked: 689 times
Noggin wrote: Thu Nov 25, 2021 8:01 pm Loving that you added BDSM-ers into the title :lol: :lol: :lol: :lol:
If we can squeeze sexy sheep in, its a very short walk to BDSM...(third door on the right).
David wrote: Thu Nov 25, 2021 8:51 pm
:lol: :lol: :lol:
Has thanked: 7821 times
Been thanked: 2531 times
GuzziPaul wrote: Thu Nov 25, 2021 7:37 pm But how do you get the ladder over the pin to install or remove the ladder?
Maybe it's just a hook?
(a hook would also solve the issue of the ladder moving around whilst SillyCar is yo-ho-ho-ing away.)
