Slipping clutch
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Slipping clutch
Post by Asian Boss »
The clutch on my XL200 slips occasionally when I give it a big handfull.
The cable is as slack as it will go so I guess some of the clutch needs replacing.
Any idea if I might get away with just replacing the friction plates? And how hard is it to do, Is it as simple as drain the oil, take the side cover off, undo the bolts on the retaining plate and replace the clutch plates?
The bike's done about 6000 miles FWIW. And is getting on for 40 years old.
Been thanked: 7526 times
Re: Slipping clutch
Lean it against something, no need to drain all the oil (unless you want to or it needs a change).
Probably only needs friction plates, but you should inspect the steels and replace if necessary.
It's pretty much as you describe process wise.
Re: Slipping clutch
Pretty easy to do, you'll need a gasket for the clutch cover and friction plates.
Asian Boss
Re: Slipping clutch
Ok, great, thank you.
How hard will the cover be to remove once unbolted? I assume it'll need hitting with a soft hammer or prying off with a screwdriver.
Re: Slipping clutch
Getting the screws out will be the trickiest bit, if they're cross head screws get the proper JIS screwdriver to undo them, you might need an impact driver, make sure all the screws are out before attempting to get the cover off, and remember to take the kick start off. Getting the cover off should be a case of tapping it with a rubber or hide mallet to break the seal, be very careful prying with a screwdriver.
If you're in any doubt take it to a bike shop, it should only be about an hours labour.
If you're still over Peterborough way I might be able to recommend someone - or have a word with some of the people you used to work with at PB, they'll know someone.
Dickyboy
Has thanked: 485 times
Been thanked: 343 times
Re: Slipping clutch
Post by Dickyboy »
Its discussions like this that make me wonder why on earth I bought a Guzzi - looking at £1000+ to get the clutch done on my 1200 sport 😕
Re: Slipping clutch
Dickyboy wrote: Wed Nov 24, 2021 10:53 am Its discussions like this that make me wonder why on earth I bought a Guzzi - looking at £1000+ to get the clutch done on my 1200 sport 😕
It's just the same as on an R series Beemer, as discussed on another thread recently :)
Re: Slipping clutch
How much, my Z1170 needs the clutch plates and springs replacing, I'm looking at £100 tops and a couple of hours work (at most)
dern
Has thanked: 1016 times
Been thanked: 1766 times
Re: Slipping clutch
Post by dern »
That's the downside of shaft drives I guess. I watched some of a video of a bloke changed the clutch in a bmw and had to strip so much of the bike down it was unbelievable. I just lean mine against a wall and stick some new plates in when I need to.
Eek...
Dickyboy
Re: Slipping clutch
Post by Dickyboy »
As post above, end up having to dismantle virtually the whole bloody bike 🙁
Re: Slipping clutch
Is the gearbox constant mesh like a "normal" bike gearbox?
Just curious how it all works.
dern
Re: Slipping clutch
Post by dern »
No idea, don't know anything about gearboxes. I assumed that they were the same but just with a single plate dry clutch between the gearbox and the engine, just like a car.
Has thanked: 6376 times
Been thanked: 4751 times
Re: Slipping clutch
dern wrote: Wed Nov 24, 2021 12:01 pm That's the downside of shaft drives I guess. I watched some of a video of a bloke changed the clutch in a bmw and had to strip so much of the bike down it was unbelievable. I just lean mine against a wall and stick some new plates in when I need to.
Eek...
Looks like Weeksy's bike cleaning regime. 'Just getting into the nooks and crannies'. :lol:
Has thanked: 2550 times
Been thanked: 6244 times
Re: Slipping clutch
Le_Fromage_Grande wrote: Wed Nov 24, 2021 2:56 pm Is the gearbox constant mesh like a "normal" bike gearbox?
I'd be very very surprised if it wasn't. In fact I'd be surprised if the gearbox in a shaft beemer wasn't the same as that in a chain bike in all but details. Even car boxes are extremely similar to bike ones, the only significant difference is the lack/presence of synchromesh and the number of dogs in the errrr....dog clutches. Even the stick shift in a car is a detail, you can convert a normal car gearbox to a bike style sequential just by changing the shift mechanism.
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Re: Slipping clutch
Post by Demannu »
Ah the joys of longitudinal cranks!
And yes, constant mesh, otherwise you'd need a gear stick!
Re: Slipping clutch
Demannu wrote: Wed Nov 24, 2021 4:39 pm And yes, constant mesh, otherwise you'd need a gear stick!
This is a weird "myth" that seems all pervasive in biking circles. Cars with a regular gearstick are constant mesh too. You have to go back a long way (or be looking at niche stuff) to find a mainstream road vehcile that's NOT constant mesh.
Edit: Just realised that the presence of synchronmesh in cars implies they're not constant mesh. If they're constant mesh what are you synching right? :D However the synchromesh synchs the dogs between the gears and selector hubs, not the gears themselves. The gears always remain meshed together....hence the name constant mesh.
Its totally possible to clutchless shift in a car just like on a bike. I advise learning how in someone else's car though ;)
Has thanked: 6187 times
Been thanked: 5087 times
Re: Slipping clutch
Count Steer wrote: Wed Nov 24, 2021 3:57 pm
That bike looks too clean (ie new-ish) to be needing a clutch replacement. Odd ...
Dickyboy
Re: Slipping clutch
Post by Dickyboy »
That's a Guzzi Griso being done, don't fancy it myself, just waiting on a rough price from Baldrick..
Has thanked: 261 times
Been thanked: 1265 times
Re: Slipping clutch
Mr. Dazzle wrote: Wed Nov 24, 2021 4:46 pm
Yeah synchromesh is an addition to constant mesh, not a replacement for it.
Edit seeing your edit: it is synchronising the dog clutches that lock individual pinions to the mainshaft. The pinions are constantly meshed.
The old British cars (before about mid-1960s) with synchromesh only on second, third and top, had a sliding pinion first gear, so first wasn’t constant mesh in those cases.
wull
Has thanked: 880 times
Been thanked: 1544 times
Re: Slipping clutch
Post by wull »
Ah, good old constant mesh gearbox, pain in my fart box!
