LED Headlight Bulbs
- Has thanked: 626 times
- Been thanked: 4072 times
LED Headlight Bulbs
I want an LED H4 Headlight bulb for my GSX because it should generate less heartburn the Halogen one - wtf should I buy, the choice is confusing
- Has thanked: 852 times
- Been thanked: 1226 times
Re: LED Headlight Bulbs
I don't know if it has changed but I think it's still illegal to stick an LED in there as a replacement bulb.
https://www.autobulbsdirect.co.uk/blog/ ... in-the-uk/
- Has thanked: 15620 times
- Been thanked: 9855 times
I read they are now legal as the new ones generate a proper beam pattern and they will pass the MOT. But I got confused on Amazon and bailed on it!
Interesting, maybe I should just fit a lower wattage halogen bulb, I rarely ride after dark and a 35W would be adequate.
- Has thanked: 2917 times
- Been thanked: 1851 times
It's a lamp not a bulb, bulbs come up in spring!
- Has thanked: 264 times
- Been thanked: 1242 times
Sorry, loser.
The English language wrote: Bulb:
the glass housing, in which a partial vacuum has been established, that contains the filament of an incandescent electric lamp
- Has thanked: 9692 times
- Been thanked: 9707 times
100 watt means 100% chance of being seen.Le_Fromage_Grande wrote: ↑Sun Nov 14, 2021 2:24 pm Interesting, maybe I should just fit a lower wattage halogen bulb, I rarely ride after dark and a 35W would be adequate.
35 watt?
Borderline sackable offence to call it a bulb when I was apprenticing.
I’ve seen people equally insistent that light bulbs- I mean lamps- must be called globes.MingtheMerciless wrote: ↑Sun Nov 14, 2021 3:34 pm Borderline sackable offence to call it a bulb when I was apprenticing.
- Has thanked: 5945 times
- Been thanked: 4933 times
Balance the risk by wearing a $500 helmet?Skub wrote: ↑Sun Nov 14, 2021 3:27 pm35 watt?Le_Fromage_Grande wrote: ↑Sun Nov 14, 2021 2:24 pm Interesting, maybe I should just fit a lower wattage halogen bulb, I rarely ride after dark and a 35W would be adequate.
- Has thanked: 2612 times
- Been thanked: 6016 times
See - if you'd asked me to guess, and it would have just been a guess, I'd have said the bulb was the screwy in bit that has filament and the lamp was the complete assembly of bulb, reflector, wires etc.MingtheMerciless wrote: ↑Sun Nov 14, 2021 3:34 pmBorderline sackable offence to call it a bulb when I was apprenticing.
I'm sure it matters enough to sack someone
I'd call the entire assembly including the reflector the lamp but an LED doesn't have a glass bulb, maybe just call it the diode.
FWIW (not much ), on vehicles, a 'lamp' is directional. To be a 'beacon' it must be visible from 360° around the vehicle.
Or the LED bulb.
- Has thanked: 25 times
- Been thanked: 54 times
Best H4 out there is the Osram.
Halfords and Amazon do them.
If you have the trade card then it’s 20% off.
@weeksy I need moderator rights please for misuse of “bulb” .
- Has thanked: 5504 times
- Been thanked: 12764 times
Sure, just paypal £250 for my number plate and you're a mod for a yearMingtheMerciless wrote: ↑Sun Nov 14, 2021 5:56 pm @weeksy I need moderator rights please for misuse of “bulb” .
