AMPED UP: GRID CYCLES’ ZERO SR ELECTRIC STREET TRACKER
- Has thanked: 5504 times
- Been thanked: 12764 times
- Has thanked: 1720 times
- Been thanked: 2013 times
Re: AMPED UP: GRID CYCLES’ ZERO SR ELECTRIC STREET TRACKER
No arguments from me on that... assuming it rides nicely, i'd be all over that when we have to move to electric. As far as 'looks' go, it ticks most of the boxes for me.
- Has thanked: 6264 times
- Been thanked: 4614 times
Looks ok that. It looks like it would be fun to ride. I'm probably in a minority but I think the original doesn't look bad either (although, amusingly, it looks a bit top heavy).
As usual, those bar end mirrors would be in the bin. The originals look and probably work better.
- Has thanked: 532 times
- Been thanked: 7242 times
- Has thanked: 626 times
- Been thanked: 4072 times
Looks okay, the seat is a bit Ducati Pantah
- Has thanked: 15620 times
- Been thanked: 9855 times
Bodywork could have been so much better, but I still love it.
- Has thanked: 9692 times
- Been thanked: 9707 times
Looks like it was designed by someone who hadn't seen a bike before. Hideous.
- Has thanked: 2612 times
- Been thanked: 6016 times
Craft beer and converse. Hipstwr rider checks out
EDIT
Actually looking at it the motor goes straight onto the front sprocket I think? Normally you'd have a couple of gear steps between the output and the sprocket (even on an ICE) but this bike appears to do it all in one hop. Hence the massively different sprockets.
Probably cause the motor spins really fast. Leccy motors generally get more efficient if you go faster, so you'll have a big reduction ratio.
EDIT
- Has thanked: 469 times
- Been thanked: 308 times
Looks pretty funky. I like the way Zero design their electric bikes without seeming to desperately want to copy ICE bike designs, but still making them look like bikes. I like the tank storage, too. Alcohol is of course the optimum use for it.
- Has thanked: 2192 times
- Been thanked: 426 times
