Fantasy Garage / Workshop essentials
Has thanked: 146 times
Been thanked: 498 times
Post by Silly Car »
The build of my garage is well on the way, 3/4 walls are up and the brick pillars will be sorted by the end of the week :banana-wrench:
Roof joists / boards / epdm roof to follow shortly after :thumbup:
Garage will be used to park cars, storage and as a workshop (as apparently the dining room isn’t for that…), so woodwork, painting, some metal work etc will all be done out there.
Given an unlimited budget and imagination, neither of which I have, what would you include?
My list so far:
PIR controlled lighting
Plumbed airline points connected to compressor
Emergency stop / safe isolation of majority of sockets
Few sockets on permanently to run chargers etc
CCTV camera & Ethernet for wifi (if needed)
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Re: Fantasy Garage / Workshop essentials
Post by DefTrap »
Workshop / dirty area separate from storage and parking?
Has thanked: 9836 times
Been thanked: 10149 times
Parker knoll and fridge. :thumbup:
Has thanked: 599 times
Been thanked: 2451 times
Double the floor space
Been thanked: 7539 times
Two post lift.
Inspection pit.
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
Fume Extractor
Costa franchise.
Swedish sauna.
Has thanked: 5453 times
Been thanked: 13102 times
I don't care about car stuff, so mine would just be bikes and bicycles.
So,
3 x Abba Skylift
1 x full sized bike workbench/hydraulic lift.
1 wall allocated to immaculate cupboard space. kitchen style, so lowers, then worktop then upper cabinets too. Plus 2 full height, 1 at each end.
Everything from Park Tools possible.
Lutin
Has thanked: 258 times
Been thanked: 332 times
Post by Lutin »
weeksy wrote: Wed Nov 03, 2021 2:35 pm Everything from Park Tools possible.
Only one of each? :mrgreen:
Post by Silly Car »
DefTrap wrote: Wed Nov 03, 2021 2:13 pm Workshop / dirty area separate from storage and parking?
Sadly not possible but a plan is to use lidded boxes / doors & tops for the storage, cars will be parked elsewhere when space is used as a workshop
Skub wrote: Wed Nov 03, 2021 2:16 pm Parker knoll and fridge. :thumbup:
:D
MrLongbeard wrote: Wed Nov 03, 2021 2:22 pm Double the floor space
Currently at 50sqm so difficult unless I steal more of the back garden, there have already been words about me extending the garage this far…
KungFooBob wrote: Wed Nov 03, 2021 2:23 pm Two post lift.
Would love to but the garage roof would need a lift as well
KungFooBob wrote: Wed Nov 03, 2021 2:24 pm Inspection pit.
I’ll happily watch you dig / cut through 300mm of reinforced concrete :wtf:
slowsider wrote: Wed Nov 03, 2021 2:25 pm Fume Extractor
Good thinking, paint spraying will be restricted to airless system using water based paint but still I’d help
KungFooBob wrote: Wed Nov 03, 2021 2:26 pm Costa franchise.
Might transfer a coffee machine out there;)
KungFooBob wrote: Wed Nov 03, 2021 2:28 pm Swedish sauna.
No space after the cars, two post ramp, Parker knoll, beer fridge, extractor fan, inspection pit :lol:
weeksy wrote: Wed Nov 03, 2021 2:35 pm I don't care about car stuff, so mine would just be bikes and bicycles.
So,
3 x Abba Skylift
GP bought my abba superbike lift, no two wheeled transport owned or planned at the moment
Tea room with kettle, fridge and cooker
Toilet
Bathroom
Laundry Area for washing / drying overalls
Proper 4 post car lift
Bike Ramp
Parking for 10 motorcycles
Somewhere to sleep
I think I need an industrial unit
Le_Fromage_Grande wrote: Wed Nov 03, 2021 3:39 pm Proper 4 post car lift
No.
You can't take the wheels off using a traditional four post lift, that's why it needs to be a two post.
KungFooBob wrote: Wed Nov 03, 2021 3:42 pm
No.
Depends where the posts are, I can't remember it ever being a problem, but it was over 30 years ago that I used one.
There was a bar each side you could lock at different heights, the car rested on these bars when you dropped the ramps away.
Last edited by Le_Fromage_Grande on Wed Nov 03, 2021 4:16 pm, edited 1 time in total.
Has thanked: 6382 times
Been thanked: 4763 times
Only really only needs one thing - and the budget is unlimited so:
A full time mechanic. :thumbup:
A four post lift usually just lifts up some ramps that a vehicle has driven on to. You then have a sliding jack in the middle which you can use to jack up the vehicle to get the wheels off.
A two post have fours arms that locate under the jacking points, much better :)
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Post by Screwdriver »
Partitioned off area for dry dusty work. Sawdust, grinding wheels, angle grinder, belt sander etc.
Local extractor (ideally cyclonic separator) in the same space.
Care needed if mixing sawdust and metal grinding. I need to build my own partitioned off area for such purposes. Can't have sawdust all over everything or grinding dust all over the lathe etc.
KungFooBob wrote: Wed Nov 03, 2021 4:15 pm A four post lift usually just lifts up some ramps that a vehicle has driven on to. You then have a sliding jack in the middle which you can use to jack up the vehicle to get the wheels off.
See my edit
But it's whatever you like, there's benefits to each type, where my Dad used to work they had both and I've used both types, and as it's a fantasy garage you could have one of each.
I've seen too many videos of cars falling off 2 posts lifts, so for a cack handed hobbyist mechanic like myself I'd go for a 4 post jobbie.
Not as much access granted but a hell of a lot less likely to wake up with an upside down car on top of you.
