Replacement MT 07 disk brake bolts
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
As above mine are showing signs of looking rank.
What replacements should I go for??? Not going titanium as there £££££, but surly I do t want to replace with Yamaha again
Thanks
Thanks
CBR650r
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: Replacement MT 07 disk brake bolts
TBH mate at the price they are and the funny shape, i'd pay £1.56 each
BOLT
9010906254
Replaces 90109-064G6
I'd then take the removed set and get them nickel coated for later use.
https://www.fowlersparts.co.uk/parts/65 ... ke-caliper
BOLT
9010906254
- formula400
But won’t those go fury again?????
Or have the been updated to be better?
CBR650r
Not if you throw a bit of ACF-50 at them maybe ? or even get them coated before fitting.formula400 wrote: ↑Wed Nov 03, 2021 8:55 am But won’t those go fury again?????
- formula400
Are there none that do not need extra work???
I’ve never used ACF50 stuff.
CBR650r
- Has thanked: 9825 times
- Been thanked: 10144 times
Titanium,the only possible choice for the discerning gentleman.
- formula400
Any idea where to find that less than £100 for front and back
CBR650r
They'll seize in the ally wheel and never come out, just buy some new Yamaha ones and keep them cleanformula400 wrote: ↑Wed Nov 03, 2021 11:48 am
Pack of 5 for £19.65?formula400 wrote: ↑Wed Nov 03, 2021 11:48 am
https://www.ebay.co.uk/itm/283851537559 ... SwOmBemqse
- Has thanked: 10263 times
- Been thanked: 6885 times
Bad bad Skub.... what about the front ?Skub wrote: ↑Wed Nov 03, 2021 2:10 pmPack of 5 for £19.65?formula400 wrote: ↑Wed Nov 03, 2021 11:48 am
Ha!weeksy wrote: ↑Wed Nov 03, 2021 2:37 pmBad bad Skub.... what about the front ?Skub wrote: ↑Wed Nov 03, 2021 2:10 pmPack of 5 for £19.65?formula400 wrote: ↑Wed Nov 03, 2021 11:48 am
Are they not all the same on the Yam?
- Been thanked: 7526 times
I thought you weren't supposed to use Ti on disc bolts, something to do with shearing.
I'm sure we've had this discussion before, where's Dazzler?
- Has thanked: 2550 times
- Been thanked: 6244 times
Short answer is, bolts (or indeed, screws!) are way more complicated than you think.
I wouldn't put Ti bolts in an ally wheel unless I knew there was all the right prep/treatment/grease (I dunno what they'd actually be in this specific application BTW). I would assume that Yamaha have thought about it properly though so I'd just fit whatever OE is.
There's many an inappropriate application of Ti bolts out there! Also, just 'cause it's fitted to a race bike doesn't make it a good idea. Very, very different usage.
As for Nickel plating - yeah it makes 'em shiny, but have you considered that it would change the required tightening torque?
- formula400
