Traction Control and Straightline Acceleration
- Been thanked: 4125 times
Having played with the traction control on my new bike, I don't think I could accelerate as hard with the TC turned off as I can by revving the knackers out of it and letting the TC control sort out the actual grip, especially in the wet, what do other people with TC think, or am I the only person stupid enough to use the TC as a form of launch control?
- Has thanked: 2948 times
- Been thanked: 1884 times
Re: Traction Control and Straightline Acceleration
Mine does have launch control but I've not got the bottle to use it (some impressive YouTube vids though). The only time I do seem to trigger the TC is powering out of roundabouts.
- Has thanked: 10282 times
- Been thanked: 6894 times
Have you tried it in the dry yet?Le_Fromage_Grande wrote: ↑Mon Nov 01, 2021 10:58 am Having played with the traction control on my new bike, I don't think I could accelerate as hard with the TC turned off as I can by revving the knackers out of it and letting the TC control sort out the actual grip, especially in the wet, what do other people with TC think, or am I the only person stupid enough to use the TC as a form of launch control?
- Bigyin
- Has thanked: 1413 times
- Been thanked: 2680 times
I struggle with getting electronics to engage. Having spent over 30 years applying the throttle and brakes so the bike doesnt flip over or lock up its hard to just whack the throttle wide open and let the bike sort out the issues. Mine normally cuts in on wet drain covers and such like but even then its rare as i have always eased the throttle slightly to avoid the wheelspin.Le_Fromage_Grande wrote: ↑Mon Nov 01, 2021 10:58 am Having played with the traction control on my new bike, I don't think I could accelerate as hard with the TC turned off as I can by revving the knackers out of it and letting the TC control sort out the actual grip, especially in the wet, what do other people with TC think, or am I the only person stupid enough to use the TC as a form of launch control?
I have tried it once or twice in the dry with a big handful of throttle (probably not a full on 0 to 100%) and with the anti wheelie on the bars go light but the front just skips about rather than hitting me in the face. I tried the ABS in the wet at Pembrey and while it worked it felt weird to trust it
Not completely dry, and certainly not warm, it's been in condition where I'd expect it to spin, in the dry it would wheelie.Yorick wrote: ↑Mon Nov 01, 2021 11:10 amHave you tried it in the dry yet?Le_Fromage_Grande wrote: ↑Mon Nov 01, 2021 10:58 am Having played with the traction control on my new bike, I don't think I could accelerate as hard with the TC turned off as I can by revving the knackers out of it and letting the TC control sort out the actual grip, especially in the wet, what do other people with TC think, or am I the only person stupid enough to use the TC as a form of launch control?
- Has thanked: 326 times
- Been thanked: 2173 times
I'm amazed your bike needs it tbh. It'll interfere enough so you feel it and as it's a basic system it won't be very smooth and it will be working when it doesn't need to be. To be really useful the newer systems with an IMU are much better and far less intrusive.
The 3 times I've ridden it have been on either wet or dirty roads, maybe on clean, smooth roads it wouldn't come on, it's not particularly noticeable when it comes on, the engine note changes a little and the light flashes.Couchy wrote: ↑Mon Nov 01, 2021 1:09 pm I'm amazed your bike needs it tbh. It'll interfere enough so you feel it and as it's a basic system it won't be very smooth and it will be working when it doesn't need to be. To be really useful the newer systems with an IMU are much better and far less intrusive.
BTW it doesn't need it, I'm riding like a twat in low gears.
Like Bigyin I have very little interference from the electronic aids whilst riding normally. Occasionally ABS cutting in on the rear brake in the wet or over gravel and traction control exiting the occasional wet bend or difficult to avoid diesel spill. I have managed to have the TC and ABS cut in in the dry but that was deliberate to experience what happens and make sure I knew what to expect.
After almost 50 years of riding and shifting without using the clutch my present bike is the first with a quick shifter. Until I got the hang of not easing the throttle slightly on the up change I hated it.
This is my first bike with ABS or TC, until Thursday the most modern bike I'd ridden was a 2002 GSXR750, and I freely admit to provoking the TC, I discovered how much fun it was pulling away on some gravel on Saturday, the bike just gripped and accelerated when I wanted it to pulling away from a layby on the A12, after that discovery I moved on to seeing how hard I could accelerate in 1st with the TC on, bloody fast as it happens.
- Has thanked: 221 times
- Been thanked: 879 times
I remember the TC/ABS Pans coming out and a road tester giving it full beans on a wet roundabout, then being surprised to find himself on his arse with 300 kilos of Honda sliding after him.
I've never, ever had the ABS cut in on my BMW, when the pump shat itself, I only got it fixed as they check it now over here.
- Has thanked: 2636 times
- Been thanked: 1523 times
The traction control on the 2018 V-Strom 1000 didn't kick in when I expected it to out in NZ - rounding a left-hand curve and accelerating out of it, only to find a wet stretch of road just round the corner with a piece of polished tarmac directly under the wheels. The back end just spun up and slid sideways. It was violent enough to have the driver behind locking his own tyres and sliding into the opposite lane.
There's only so much cack handed riding it can cope withThe Spin Doctor wrote: ↑Mon Nov 01, 2021 9:21 pm The traction control on the 2018 V-Strom 1000 didn't kick in when I expected it to out in NZ - rounding a left-hand curve and accelerating out of it, only to find a wet stretch of road just round the corner with a piece of polished tarmac directly under the wheels. The back end just spun up and slid sideways. It was violent enough to have the driver behind locking his own tyres and sliding into the opposite lane.
Even the top MotoGP and WSB lads have high-sides. It's not magic.
- Has thanked: 15999 times
- Been thanked: 10262 times
- Bigyin
- Been thanked: 7545 times
Pedrobot had a massive high side when the rear wheel speed sensor wire snapped on his bike, goes to show how much they do actually rely on the stuff like that.
I think there's a good chance the TC on my bike could cause a high side, when it does it's thing you get a tiny bit of spin followed by grip, leant over the transfer from spin to grip could make the bike stand up, I don't think I'll be testing this.
- Has thanked: 5456 times
- Been thanked: 13103 times
I'm fairly sure Suzuki have this pretty much nailed in terms of ECU/IMU/whatever as do the others. Highsiding takes a fair bit of comittment on newer bikes i reckon.Le_Fromage_Grande wrote: ↑Tue Nov 02, 2021 10:18 am I think there's a good chance the TC on my bike could cause a high side, when it does it's thing you get a tiny bit of spin followed by grip, leant over the transfer from spin to grip could make the bike stand up, I don't think I'll be testing this.
They probably have, but I don't think I'll dick about with trying to make the TC come on while leant over, it'll end in tears, my tears.weeksy wrote: ↑Tue Nov 02, 2021 10:22 amI'm fairly sure Suzuki have this pretty much nailed in terms of ECU/IMU/whatever as do the others. Highsiding takes a fair bit of comittment on newer bikes i reckon.Le_Fromage_Grande wrote: ↑Tue Nov 02, 2021 10:18 am I think there's a good chance the TC on my bike could cause a high side, when it does it's thing you get a tiny bit of spin followed by grip, leant over the transfer from spin to grip could make the bike stand up, I don't think I'll be testing this.
